distributor timing
Old Jan 22, 2003 | 09:44 AM
philipkrotch's Avatar
Default distributor timing
when i put the new distributor on my car i realized that it had moved somewhat when i put the new one in. i tried not to move it much but it did neways. it didnt turn the engine over, it just spun the distributor. would i have to use a timing gun to make it right, or would it have nothing to do with it? it runs fine now but when i first started it up the idle went up and down, then the next time i started it it was fine. i dont think it really maters cuz it runs fine, but i want to make sure its ok for my engine cuz i just put a new tranny and clutch in and i havent drove the damn thing for about 6 months cuz it was broken and i was broke.
Old Jan 22, 2003 | 10:02 AM
RaceTilIDie's Avatar
Default Re: distributor timing (philipkrotch)
Get a timing light for $30. If you don't want to buy one, you can probably borrow one form Autozone.
Old Jan 22, 2003 | 11:55 AM
D21X's Avatar
Default Re: distributor timing (RaceTilIDie)
yeah i replaced my distributor too and the car runs fine but i'm not sure if my timing is right. anyone have a DIY on how to do timing???
Old Jan 23, 2003 | 04:09 AM
Stew Pidasso's Avatar
Default Re: distributor timing (D21X)
This is for an integra but I believe the process is the same for Accords
http://www.vtec.net/articles/view-ar...rticle_id=3374
For Accords...
http://www.accordracing.com/how-tos/timing_adjust.htm
Old Jan 23, 2003 | 08:13 AM
glassyaccord92's Avatar
Default Re: distributor timing (Stew Pidasso)
hey in order to set your timing perfect i am highly highly recommending getting a timing light. i believe one guy allready posted how good luck man
Old Jan 23, 2003 | 10:25 AM
Default Re: distributor timing (glassyaccord92)
would it hgurt it in any way to leave it the way it is or do i HAVE to set the timing on it, it runs just fine but do i ABSOULUTLEY HAVE to adjust the timing?
Old Jan 23, 2003 | 10:32 AM
main thing is listen for pinging, if it is too advanced it will ping due to detonation which will kill your motor.
Old Jan 23, 2003 | 10:40 AM
raceACCORDingly's Avatar
if u advanced it a degree or two accidentally and hear no pinging/detenation then its fine. if you retarded it you should be feeling a tad bit sluggier.
heres a how-to do it the "ghetto" way: http://members.tripod.com/~Pre_ludE/pmods.html
[Modified by raceACCORDingly, 7:42 PM 1/23/2003]
Kaminsky
14
Aug 7, 2015 03:03 PM
jakscivic
Jun 2, 2010 07:29 PM
azzurribaggio
Jun 26, 2009 09:25 PM
Feriofan
Jul 29, 2004 11:27 AM
krazn
Feb 22, 2004 11:11 AM
