trick to replacing valve seals
Old Jan 22, 2003 | 06:05 AM
kyle h.'s Avatar
Default trick to replacing valve seals
i did all the intake seals last night. tonight i'll be doing the exhaust valve seals. i was wondering if there is a trick to getting the seals off? i pry a good bit and they eventually come off, but i nick up some parts of the head in the mean time. just keep prying them off with a screw driver or is there a trick?
Old Jan 22, 2003 | 06:31 AM
Spade's Avatar
Default Re: trick to replacing valve seals (kyle h.)
Slow down and take your time, that's the trick.
Old Jan 22, 2003 | 09:48 AM
sgT's Avatar
sgT
i take vice pliers and twist and pry
Old Jan 22, 2003 | 02:39 PM
boosted3g's Avatar
Default Re: trick to replacing valve seals (sgT)
i would jsut go and get the right tool. Valve seal removers are a very simple tool and cost very little. i spend maybe 15 bucks on mine.
Old Jan 22, 2003 | 06:29 PM
kyle h.'s Avatar
Default Re: trick to replacing valve seals (boosted3g)
so there is a tool for them!? whats it look like?
Old Jan 22, 2003 | 06:35 PM
ULTRA911's Avatar
i got mines from the schley products. my little sister described it as a tool used to pull out the wisdom tooth. look like pliers with a circular shape to grip the valve seals really good. you could do the whole exhaust side in less than minute.
Old Jan 22, 2003 | 06:37 PM
ULTRA911's Avatar
Default Re: trick to replacing valve seals (ULTRA911)
oh yea, if kragen/autozone has it, do a buy & return.
Old Jan 22, 2003 | 07:25 PM
IN VTEC's Avatar
I don't think it really grips the valve seal with a lot of side compression. Rather, it mainly lifts from the seat of the seal and the side compression is used to retain the seal to keep it from dropping or flying out.
Old Jan 23, 2003 | 05:19 AM
fathergoose's Avatar
Always shoot air in the head to prevent the valves fron falling into it!!!
Old Jan 27, 2003 | 08:07 PM
kyle h.'s Avatar
Default Re: trick to replacing valve seals (fathergoose)
ah...the head is off. i found the trick. dont do them one at a time. remove all intake valves, then u have more room to pry. then put it back together..and remove all exhaust valve....and repeat.
jalenda9
Engine Machining & Assembly
Jun 21, 2016 01:46 PM
Red D Dragon
May 5, 2005 10:16 AM
D-series ninja
Jan 11, 2005 11:14 PM
1.8EG-T
Dec 14, 2003 02:56 PM
