Nology Hot Wires
Old Jan 21, 2003 | 03:22 PM
General Kills's Avatar
Default Nology Hot Wires
Do any of you guys have experienced with these good/bad? How are they on Hondas compared to other cars?
Old Jan 21, 2003 | 03:27 PM
qcoffey's Avatar
Default Re: Nology Hot Wires (Tunerdude)
I am not a huge fan if their wires. For a vehicle that is running a stock ignition system I guess they're ok, but stock is better. For vehicles with aftermarket ignition systems typically the manufacturer of the ignition system makes wires that work with their applications, i.e. MSD or Jacobs.
Old Jan 21, 2003 | 10:20 PM
RCautoworks's Avatar
There a waste of money, my friend has them and says they were a big waste. Go with some ngks or another good cheap brand.
Old Jan 22, 2003 | 06:15 AM
RABBIT9's Avatar
Default Re: Nology Hot Wires (90blackcrx)
I'm going to disagree. I'm running an otherwise stock ignition, and they did make a noticeable difference.
Old Jan 22, 2003 | 06:23 AM
1506's Avatar
I had them and the suck. Would never fit right and snap on the plugs. Stick to NGK or OEM. They fit and work good. Very rarely do NGK or OEM go bad.
Old Jan 22, 2003 | 06:26 AM
RaceTilIDie's Avatar
Default Re: Nology Hot Wires (1506)
I hear the direct hits perform better on the dyno. They are like .75 HP compared to .5 HP for the Nology. Changing your oil can get you 3 HP.
Old Jan 22, 2003 | 07:47 AM
hypa's Avatar
Default Re: Nology Hot Wires (RaceTilIDie)
I like my nology wires. I had a stumbling problem when I boosted, and changed the plugs (NGK BKR7E - fresh plugs) to the Beru ones. The stumble was gone, and the car ran better then ever.
Old Jan 22, 2003 | 08:01 AM
Chugger's Avatar
ngk plugs, ngk wires and a new rotor and cap youd be surprised what you gain
Steeve_Civic
Jan 6, 2013 12:16 PM
b16bri
Sep 30, 2010 05:45 AM
DRKSol
May 22, 2004 11:33 PM
MooreBoost
Sep 28, 2002 07:58 PM
vtec69
Apr 9, 2002 06:29 PM
