high hp Ignition set-ups
Old Sep 22, 2010 | 11:37 AM
b16bri's Avatar
Default high hp Ignition set-ups
What are the high hp guys running for Ignition setups 450-550hp I'm looking for ideas. I know a lot of people run the oem with the msd blaser coils but i know after some time thoes coils make the oem dizzy **** the bed it's happend to be on my last set up. So what are you guys running
Old Sep 22, 2010 | 11:59 AM
DelSolMarine's Avatar
Default Re: high hp Ignition set-ups
you can run all stock ignition... just have good plugs and wires
i personally have the m&w pro 10 setup, crane coil, ngk iridium 8's, and ngk wires... Charm City Tuning is a great vendor
Old Sep 22, 2010 | 12:19 PM
worktoomuch's Avatar
ya I made 585 whp on a stock ignition system with NGK wires........
I'm currently using the AEM coil on plug stuff and I've been happy with it.
dyno chart from last week at 25psi. SC61 E85 H22
Old Sep 22, 2010 | 12:21 PM
jdm inc's Avatar
M&W pro 10 ignition kit. FTW
had msd digital 6 but it blew my igniter out and i said eff it and went with pro 10 and never had any problems since then!
http://t1raceparts.com/en/products/d...ro-10-kit.html
Old Sep 22, 2010 | 12:29 PM
extralargenog's Avatar
ou dont need **** for your power. spend the money somewhere else... I made 620 WHP on a bone stock JDM H22 dist. Straight off the crate, not even a new cap or rotor. Gapped plugs at .019 and call it good
I have a 7AL2 and blaster SS coil on it now.. But only because im going to make 700+ here in a couple weeks
Old Sep 22, 2010 | 01:08 PM
b16bri's Avatar
How dose the m&w work is it just plug and play and do u use to the stock coil and dizzy or do u need to get a different one
Old Sep 22, 2010 | 01:24 PM
You in no way shape or form need the MW10. Your goals arent even near surpassing an OEM ignition. At all.
Old Sep 22, 2010 | 01:28 PM
h22 civic's Avatar
you running the epm and twin fire or something else?
Old Sep 22, 2010 | 03:55 PM
gc8dc95's Avatar
I use an MSD Digital 6 and HVC-II Coil....SC61@22psi, but from what I have seen you dont really need anything for under 500whp
Old Sep 22, 2010 | 05:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
your level, stock woth a tight gap will be ok.
my setup, stock dizzy, msd cap, rotor, wires, blaster ss coil, 6al box.
740whp reving to 10.8k
Old Sep 23, 2010 | 12:09 PM
yes AEM EPM, twin fire, and their coils as well.
Old Sep 23, 2010 | 04:06 PM
h22 civic's Avatar
newer twinfire or older?
Old Sep 23, 2010 | 04:32 PM
heavy duty's Avatar
Has anyone running the m&w 10 had any bad luck out of it. I have also made over 600hp on stock well a msd cap and blaster ss and that was it.
Old Sep 23, 2010 | 05:17 PM
sanman000719's Avatar
didnt i just read in the speedfactory interveiw that they are still on a dizzy@900hp
I run the m&pro14 with a t1 trigger and cop
Old Sep 23, 2010 | 05:46 PM
Turbo-LS's Avatar
running a summit digital ignition box with msd cap/rotor combo with a blaster ss coil
Having issues with the coil i believe but other than that works great. alot of increase on spark over stock and the digital box plays well with the ignitors, upgrading to a hvc-II over the winter while the car sits
Garage 808 Hatch's Avatar
Distributor with digital 6 and an SS coil making 800whp here. Reving 11k no issues.
Old Sep 23, 2010 | 05:58 PM
HamiltonRex's Avatar
the m&w is pretty badass. I use a dynatec arc2 with stock coils. The fastest FWD 4 cyl on gas in the world runs a dynatec arc2, and there very affordable.
Old Sep 23, 2010 | 07:11 PM
jnv255's Avatar
Digital6 and ss coil. The only problem I had was the MSD being to close the the Hondata and it was causing interfernce. I moved the box away from the S300'and it was fine.
sig...
Old Sep 23, 2010 | 07:35 PM
DC4KiD's Avatar
T67 on 17 PSI here, making 470+ WHP on 91 oct pump gas with ALL STOCK ignition setup (NGK 8s gapped at .025").
Wll be going with an MSD external coil setup before re-tuning on higher boost.
Old Sep 23, 2010 | 08:01 PM
runsfromdacops's Avatar
i just made 601/352 on 19 psi. bone stock disszy. gap the plugs down and call it a day
Old Sep 24, 2010 | 04:24 AM
what is this setup?
Old Sep 24, 2010 | 04:26 AM
Turbo-LS's Avatar
Dc4kid. When I went from stock coil to an msd external (maybe just th coil I chose) I had to gap my plugs way down. Stick with stock unless going with a box as well IMO
Old Sep 24, 2010 | 04:40 AM
I had an old one and they updated it to the newest revision when it decided it didn't want to work.
Old Sep 24, 2010 | 04:41 AM
Zer0_SpeedWorks's Avatar
made almost 700 with stock ignition...now im shooting for more with pro10 and ps92 coil setup from t1
Old Sep 25, 2010 | 11:47 AM
rs250nut's Avatar
Suprised more people are not going coil on plug.
