Stupid Problem, please give opinions?
Old Jan 21, 2003 | 10:33 AM
MysteryWagon's Avatar
Default Stupid Problem, please give opinions?
this weekend I put a Victor X mani. on a first gen B16. Instructions thought it would be a good Idea to remove oil filter, for easier passage to the bottom bolts. after doing so and finishing the whole manifold swap. We put everything on including the oil filter.
My questions it when a oil filter is aboout 2100 miles old and it is not to great of a oil filter like a "FRAM" oil filter. After taking it off for this mani swap would the oil filter be damaged to the point that it would cause all my oil in the engine to end up on the floor after starting.
I am ticked and hoping that this is the problem. Cause I don't really see any other reason this would happen
by the way when I put the oil filter on instead of it letting me twist to tighten it, it just came to a dead stop like I hit a wall. it still felt flush with the block but maybe I cross threaded it. Has anyone else ran into this problem?
I would be most appriciative.
thanks
Justin
Old Jan 21, 2003 | 10:35 AM
RaceTilIDie's Avatar
Default Re: Stupid Problem, please give opinions? (MysteryWagon)
Is the rubber gasket still there?
Old Jan 21, 2003 | 10:42 AM
Spade's Avatar
Default Re: Stupid Problem, please give opinions? (RaceTilIDie)
I have helped a friend in the past who had 4...that's right 4 oil filter gaskets stuck to each other from past oil changes.
Old Jan 21, 2003 | 10:43 AM
the oil filter gasket?
do you think that could cause all the oil to come out with the engine being on for like 6 seconds.
Old Jan 21, 2003 | 10:55 AM
Spade's Avatar
Hell yeah if it isn't sealed. The oil pump, pumps directly to the filter then from there it goes to the rest of the engine.
Pull the old filter and see where the gasket is.
Old Jan 21, 2003 | 12:36 PM
Default Re: Stupid Problem, please give opinions? (Spade)
thanks I was being an idiot and rushing and did not give my self the time to come to that conclusion.
Justin
r33dm0n3y
Jun 23, 2009 05:30 PM
devin_hoang
36
Mar 24, 2009 01:08 PM
bengro
Acura TL, RL & ZDX
Dec 6, 2004 04:20 PM
89JDMcrx
Mar 30, 2003 07:59 AM
Mover
Feb 20, 2003 09:21 AM
