problem getting keeper off, help pretty please
Old Jan 21, 2003 | 06:12 AM
whitelightning's Avatar
Default problem getting keeper off, help pretty please
well, i got 15 of 16 valves off, the last one is being a pain in the ****!!!!!!!!i've spent the same amount of time on the last one, that i 've spent on taking the other 15 out...grrrrr
i have tapped it many times, oiled it, wd40 the keeper, ...each time i compress it, the valve moves...but the keeper wont budge...
should i get a different type of compressor? (the head is out) tempted to drill that sucker out....
i have the valvespring compressor similar to snap-on where it is bolted on top of of the head with the bar going across... any tips is greatly appreciated.
Old Jan 21, 2003 | 06:29 AM
RaceTilIDie's Avatar
Default Re: problem getting keeper off, help pretty please (whitelightning)
Use a clamp/vise grip, etc to somehow clamp the valve shut. The tool you are using (if it's what it sounds like) is meant for the head on motor, and you pressurize the cylinder to keep the valves closed. WHen the head is off there is a compressor that clamps around the head, holding the valves shut.
Old Jan 21, 2003 | 06:42 AM
IN VTEC's Avatar
Be patient with it.
Push it all down to bind the spring. Let it come up a little and then give it a quick push all the way down again. Use the magnetic pickup tool to help it along.
Old Jan 21, 2003 | 08:02 AM
Default Re: problem getting keeper off, help pretty please (IN VTEC)
yeah, i've been pretty patient with it...it just won't budge, the others came off right when it compressed the valves....
Old Jan 21, 2003 | 08:28 AM
IN VTEC's Avatar
Just bounce it up/down with some good effort. It'll come up.
Old Jan 21, 2003 | 11:26 AM
Yeah, i've done that...trust me...i'll try again though...i might just end up getting a different spring compressor, one that keeps the valve shut, i'm thinking that would work without tooooo much effort.
Old Jan 21, 2003 | 12:24 PM
CHEETAH's Avatar
spark plug socket with short 3/8" extension and small sledge mallet ...
greg
Old Jan 21, 2003 | 12:37 PM
sgT's Avatar
sgT
Default Re: problem getting keeper off, help pretty please (CHEETAH)
did you put a rag under the valve to help hold it up??
Old Jan 21, 2003 | 01:36 PM
yeah, i've done that with a 17 socket, fits pretty good around the retainer....tapped many times...
sgt, didn't do the rag though, i've put a little socket where the valve was sitting, i'll try the rag hope this works...
[Modified by whitelightning, 2:38 PM 1/21/2003]
Old Jan 22, 2003 | 05:34 AM
GOT IT OFF!!!!!! after a touch oil, rag where the valve is to help keep it close(TY SGT! ) tapping somemore and playing with it somemore... it popped off!!!!THANKS GUYS!!!
[Modified by whitelightning, 6:34 AM 1/22/2003]
j spec
May 14, 2006 02:54 PM
Curtis2kul
Jun 21, 2004 04:59 AM
ricearoni56
16
Jun 19, 2004 09:16 PM
see_our_vtec
Sep 21, 2003 10:24 PM
