oil found on exhaust side?
Old Jan 21, 2003 | 01:53 AM
MiraiZ's Avatar
Default oil found on exhaust side?
Engine was pulled from my car today and they found oil residue in the downpipe... they're is no play in the turbine shaft and the turbo has less than 1000 miles on it. Haven't taken the head off the engine yet, but the mechanic says that my turbo may need rebuilding too.
question:
can oil in the exhaust side be cause by bad piston rings or is it more likely to be blown turbo seals?
Old Jan 21, 2003 | 01:55 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: oil found on exhaust side? (MiraiZ)
Could be both.
art
Old Jan 21, 2003 | 01:57 AM
MiraiZ's Avatar
Default Re: oil found on exhaust side? (Arturbo)
what would cause the seal to blow after 1000 miles? Id on't want to repeat the same mistake if it has to do with my handling of the turbo
Old Jan 21, 2003 | 02:34 AM
Arturbo's Avatar
Better than steak
25 Year Member
I doubt its blown.
Old Jan 21, 2003 | 02:38 AM
MiraiZ's Avatar
you think its just my piston rings then? either or is fine but both is gonna hurt!
Old Jan 21, 2003 | 02:52 AM
Arturbo's Avatar
Better than steak
25 Year Member
what happend to your piston rings? You didnt have your fmax kit that long, did you?
art
Old Jan 21, 2003 | 03:16 AM
MiraiZ's Avatar
11:1 compression
boost spike to 1 BAR
running really rich
pos untuned MF2 on for 3 months
take your pick...but I was gonna get low comp. pistons anyways...just came sooner and more unexpectedly than I wanted
[Modified by MiraiZ, 9:17 PM 1/21/2003]
Old Jan 21, 2003 | 04:09 AM
turbopanda's Avatar
i'm in the same situation as you MiriaZ
although there is a lot of air pressure coming out of my valve cover breather, and sometimes white smoke comes out. i'm very upset.. spent so much money already.. guess now I have no choice but to move to step2 of my project.. buy JE 84mms, swap in B18C crankshaft and use my existing B18C eagle rods into my B20B block, and set new C/R. *sigh*
Old Jan 21, 2003 | 04:18 AM
MiraiZ's Avatar
Default Re: oil found on exhaust side? (turbopanda)
well...hopefully I get it right this time...this garage is suppose to be damn good...
Old Jan 21, 2003 | 10:26 AM
turbopanda's Avatar
good luck
Old Jan 21, 2003 | 01:31 PM
MiraiZ's Avatar
any other experiences with oil on the exhaust side?
Old Jan 21, 2003 | 01:35 PM
CovertFI's Avatar
white smoke might not be oil!! also just do a compression check to rule out the turbo as the cause.
Old Jan 22, 2003 | 06:18 PM
neiloneil03's Avatar
if you have to big of oil feed line to turbo(i.e. -4) then you need to go down to size -3
Old Jan 25, 2003 | 07:34 AM
JDM_DOHC_SiR's Avatar
New User
Glad you finally found someone that could help you Bob.. ...my *** was just to damn busy if you know what I mean ... But I bet you a good chunk of $ that they take the block down to the same shop where I was going to have yours honed at Mitomi Bro's in Yokohama.. 90% of the speed shops in that area use them....
Talk with ya in about 4~6months when I get off the boat
-Dave
kyleboosted_94
Jan 5, 2018 07:08 PM
honda_fan06
Mar 25, 2011 04:49 PM
LShatchie
Aug 4, 2005 02:43 PM
crxtreme27
Aug 26, 2003 01:25 PM
