Moroso pan + Fram SureDrain?
Problem: I am afraid of striping the oil drain bolt on my Moroso pan (for my 1997 B18C1) .
Possible Solutuon: Replace the drain bolt with a Fram Sure Drain. Since the "bolt" won't need to be removed and re-installed after each oil change, it will reduce the chances of striping the bolt.
Qestion: Which Sure Drain kit do I need? Anyone know the pitch and diameter of the stock Moroso pan bolt (again, for a 1997 B18C1 motor)
Thanks
Thanks
My roommate tried that Sure Drain thing on his car.....after he finished the first oil change he said he could **** with more flow than his Sure Drain did. He shortly removed it and went back to stock. But I personally have not tried it on my car.
Just be gentle with your Moroso drain bolt.
sleeperhonda
10
Aug 20, 2013 08:18 AM
