... smoke... at idle and high rpms only
This is smoke out of the exhaust right? My guess is that it is smoking all the time but you just don't know it. At idle its easy to see smoke forming because you're in one spot, but as you accelerate it becomes a lot harder to notice since you are moving. Normally people only notice it while moving if their engine is under heavy load or high rpms.
I would say piston rings.
Mine does the same thing and my motor is brand new (rebuilt)! But mine only smokes at idle. and not all the time either just some times. At high rpms its smokes BLACK but we all know what that means.....hehe
blue smoke means oil burning, if i am right.
1. Check coolant for oil deposits
2. Check your piping for oil
3. Do a Compression test and/or leakdown test
Either the turbos oil seals are bad, piston rings are bad, or blown headgasket.
