... smoke... at idle and high rpms only
... just like it says... car smokes at stop lights and high rpms only... anyone have an idea what the problem could be... lemme know... thanks...
Re: ... smoke... at idle and high rpms only (1.8T_EG)
This is smoke out of the exhaust right? My guess is that it is smoking all the time but you just don't know it. At idle its easy to see smoke forming because you're in one spot, but as you accelerate it becomes a lot harder to notice since you are moving. Normally people only notice it while moving if their engine is under heavy load or high rpms.
I would say piston rings.
Re: ... smoke... at idle and high rpms only (trbob16a)
What color is the smoke. I have heard alot of people saying it could have to do with a blown head gasket or the rings. check it out.
Re: ... smoke... at idle and high rpms only (Ek00si)
Mine does the same thing and my motor is brand new (rebuilt)! But mine only smokes at idle. and not all the time either just some times. At high rpms its smokes BLACK but we all know what that means.....hehe
Re: ... smoke... at idle and high rpms only (ekb18c)
block has about 5-7000 miles on it, was broke in under 3000 rpm for the first 1000 miles. The turbo isnt no older thatn 8-9 months. The smoke is blue.
Re: ... smoke... at idle and high rpms only (gsrcivict)
blue smoke means oil burning, if i am right.
1. Check coolant for oil deposits
2. Check your piping for oil
3. Do a Compression test and/or leakdown test
Either the turbos oil seals are bad, piston rings are bad, or blown headgasket.
