Reset stock ECU?
Old Jan 19, 2003 | 07:54 PM
GSRGuy17's Avatar
Default Reset stock ECU?
Okay, I have a stock '94 GSR. I've come up w/ a very interesting intake setup for the track that makes it completely ram-air, w/ no restricition (don't use it on the street, I know), and was wondering... Because of the wildly increased flow over stock, should I reset my ECU just as a precaution, so I don't run lean? And, can I do this just by disconnecting the fuse, waiting ten minutes, plugging the fuse back in, and letting the car idle for a while? Thanks.
Old Jan 20, 2003 | 01:28 AM
VTEC-DA's Avatar
Default Re: Reset stock ECU? (GSRGuy17)
An intake wont throw your car off that much, not matter how wildy increased the flow is. Reset the ECU if it makes you feel better, it wont hurt anything. And only pull the fuse for 10 seconds, not 10 mintes.
Old Jan 20, 2003 | 08:31 AM
cp_harrington's Avatar
Default Re: Reset stock ECU? (VTEC-DA)
how do you reset the ecu?
Old Jan 20, 2003 | 03:37 PM
GSRGuy17's Avatar
thanks.. yeah, I know it probably won't make a difference, but on a car w/ 150K miles, I just wanna make sure I don't run lean. Thanks alot
Old Jan 20, 2003 | 04:29 PM
redcxhatch's Avatar
Ram Air is bad, unless your an engineer. It creates a pressure zone, causing air to go around intake...trust me.
Old Jan 20, 2003 | 05:28 PM
VTEC-DA's Avatar
Default Re: Reset stock ECU? (cp_harrington)
Pull back-up fuse in the fuse box under the hood. Wait 5-10 seconds. Plug back in. Start car with EVERYTHING off. Let idle for 5-10 minutes. Turn car off. ECU is reset.
Old Jan 20, 2003 | 06:01 PM
Benj's Avatar
Is this the same procedure with a non-stock ECU (Erick's racing)?
burntkookie
Oct 14, 2009 01:08 AM
mrmonk
Dec 5, 2003 12:17 PM
cp_harrington
Jan 20, 2003 08:35 PM
eerieCivic
Mar 12, 2002 02:25 PM
illusion
Feb 18, 2002 03:02 PM
