hondata wont datalog. Any ideas?
Ok the other day it worked, but now when i connect it just says conection error. I have made no changes to the laptop or the hondata setup. The red light on the box flashes once and then stays on just like it should
Double check the serial cable connection between the laptop and the interface box. Also make sure the serial settings are correct and that in the datalogging options you did not tell hondata what ecu and version of software you have.
Hmm weird. I'd check the Hondalogger settings then as that sounds like it may have something funky goin on. If it doesn't work let me know and I may be able to swing over w/ my copy and see if I can bring a datalogging session up.
As far as the idle goes... it's annoying as hell huh?
yeah man that idle **** is a pain in the ***. Do you work tomorrow? Ill get ahold of ya. maybe my laptop port is shitty. It is old so ya never know. Thanks Hey what weight flywheel do you have? This one has a 11lb one and its hard as hell to drive
I'm running an 11lb Sohfast lightened stock flywheel w/ an ACT Xtreme pressure plate and 6 puck unsprung disc. It's not too bad on the street. Gonna change out to an ACT flywheel sometime this spring I think though. As the Sohfast flywheel isn't legal for any passes at the track 11.99 or lower.
so you plan to hit 11's huh. The big dawg!! J/K man, Ill be with ya running 14's in my 240sx but hey it will look good. Cause after this im done with FWD's. Just to much work. thanks for the help
