How long to install Cam & Cam Gears?
Old Jan 18, 2003 | 09:46 PM
ModAddict's Avatar
Default How long to install Cam & Cam Gears?
Aside from tuning, how long should it take to do the swap on a 99 Civic Si?
Old Jan 18, 2003 | 09:49 PM
tominos's Avatar
Default Re: How long to install Cam & Cam Gears? (ModAddict)
depends if you've done it before or not. could take 1-2 hours, could take 2 days. but 2 hours should be good.
Old Jan 18, 2003 | 09:54 PM
ModAddict's Avatar
Default Re: How long to install Cam & Cam Gears? (tominos)
Someone that's done it a number of times.
Old Jan 18, 2003 | 11:50 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
http://www.c-speedracing.com
Old Jan 19, 2003 | 05:11 AM
eg6ajk's Avatar
make sure you leave the motor to cool overnight or for at least few hours. it will take you about 4-6hrs all in all if you haven't done it before. just take your time and follow a plan.
Old Jan 19, 2003 | 08:24 AM
altoid's Avatar
Default Re: How long to install Cam & Cam Gears? (eg6ajk)
good advice there, i did a cam swap and total took about 8 hours (it was 28 degrees out), for the reason of me breaking a bolt inside the head and stretching a bolt, i was furious, but just make sure you know what you're up against. Before i did it i red the manual a couple of times just to make sure how to properly remove everything and put it back on. good luck
[Modified by altoid, 12:25 PM 1/19/2003]
Old Jan 19, 2003 | 08:36 AM
Goldfingiz's Avatar
Guys it takes 15 minutes to get to the cams...it's only a few bolts =\
Goldfingiz
Old Jan 19, 2003 | 06:45 PM
Benj's Avatar
Default Re: How long to install Cam & Cam Gears? (Goldfingiz)
how about only the cam gears? how long would it take?
Old Jan 19, 2007 | 05:13 PM
seadonkeyraypiss's Avatar
Default Re: How long to install Cam & Cam Gears? (Benj)
About 10-15 min less.
Old Jan 19, 2007 | 05:25 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: How long to install Cam & Cam Gears? (seadonkeyraypiss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seadonkeyraypiss &raquo;</TD></TR><TR><TD CLASS="quote">About 10-15 min less.</TD></TR></TABLE>
You bumped a thread from 2003?!?!?
Old Jan 20, 2007 | 11:22 PM
DC4R27's Avatar
Default Re: How long to install Cam & Cam Gears? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
You bumped a thread from 2003?!?!?</TD></TR></TABLE>
LOLOLOLOLOLOL
Old Jan 24, 2007 | 11:20 PM
Default Re: How long to install Cam & Cam Gears? (DC4 reals)
oops1 I hope he figured it out by now.
1BADEGDC2
Jul 9, 2008 06:45 PM
Ek4 life
Nov 29, 2007 08:06 AM
calvinPGMFI
Feb 24, 2006 04:38 AM
IIVIIoOkY
Feb 4, 2006 10:19 PM
boostin b16
Mar 18, 2003 07:13 PM
