Greddy turbo question?
just wanted to make a few things clear, is it true that the greddy turbo(b18c1 kit) can't boost more then 12lbs witout it acting up cause of the internal wastegate? thanks
i have the greddy ki-- no not a problem-- the turbo will flow up to 20 psi nicely-- it tapers right at 18 from a friends expeirience and cant hold it well but a good boost controller helps -- like the AVCR from apexi and HKS EVC
this is kind of a hard question to answer because some people have problems holding 10psi and others hold all the way to 18psi. so it depends on a lot of things. sorry if this is not the answer you have been looking for, but yes some people have held the power while others have problems.
boostincoupe
Jan 24, 2005 02:31 AM
GreddySi99
Jul 9, 2003 10:29 AM
