Where to attach the oil return lines on my turbo ??
Old Jan 18, 2003 | 04:26 PM
iperez's Avatar
Default Where to attach the oil return lines on my turbo ??
I am trying to put together my turbo kit and I have a question. I know I will need to tap an oil line on my oil pan to feed the turbo but I what about the return line ?? Where do I connect the oil return line that exits the turbo ?? Also, where on the oil pan should I tap for the oil line or, does it make a difference ?? Thanks guys !!
Old Jan 18, 2003 | 04:29 PM
ls-t del sol's Avatar
Default Re: Where to attach the oil return lines on my turbo ?? (iperez)
run the oil feed off the hole on the back of the block for the factory oil pressure sensor, with a 1/8 npt tee. Run the oil return to the oil pan. Theres about 2 billion archived threads involving oil feed and return lines, just search for them
Old Jan 18, 2003 | 04:33 PM
iperez's Avatar
Default Re: Where to attach the oil return lines on my turbo ?? (SolReaver)
Thanks for the help !! I will run a search for more info.
Old Jan 18, 2003 | 04:36 PM
4th post in this thread should tell you everything you ever wanted to know
https://honda-tech.com/zerothread?id=268110
gabe768
May 22, 2010 01:18 PM
jprelude92
Aug 30, 2008 07:12 AM
Gtimportfanatic
Oct 31, 2007 09:06 PM
killamike0001
Sep 6, 2007 12:22 PM
nsxblueteg
Jun 10, 2003 11:08 AM
