Need help, car died while driving!
While i was driving home last night my car started to bog really bad. It lost all power and just died. the motor cranks and feels like it wants to start, but all it does is backfire. any suggestions?? i havent had time to try anything yet so any input would be much appreciated. Thanks
Stock 89 CRX SI
Stock 89 CRX SI
Stock 89 CRX SI
Stock 89 CRX SI
I have the same problem too we tried the everything it has fuel,spark, timing is right, and has compression I dont have a clue as to what it could be . PLEASE HELP ME TOO
It was most likely your main relay or the rotor in the distributor. Personally I have had no problems with the rotor as of now, but I did have to fix my main relay. There are 2 things that you can do to fix the main relay.
1. You can replace the whole unit for about $60 CAN ($40 US)
2. Re-solder the old soldering points on the main relay as they crack due to age and won't allow for proper circuitry flow.
http://www.crxsi.com/resources/repair/fixing_main_relay/
crxsi.com has a great How-To article on main relays. Check that out. If it's the distributor, someone else who has had problems with it will have to drop their 2 cents.
-Andrew
-Andrew
I had that same problem once. I had spark, fuel, timing etc.... Turned out to be the screw backed its way out of my rotor in my dizzy. Back firing came from having the spark at the wrong time. (Rotor was free spinning in the Dizzy)....... Take your cap off and check that first......
Similar sounding thing happened to me, the car all of a sudden bogged really bad and then died. Ended up being the igniter (which there was a recall on a long time ago). Something to check. If it is that, the dealer will fix it for free.
Thanks for the help... this is exactly what happened to mine...
wood 1
Dec 12, 2006 07:46 PM
DeDonDeRosa
Dec 1, 2003 04:31 PM
