help quick.. (like always) when removing power steering....
Old Jan 17, 2003 | 03:14 PM
done's Avatar
Default help quick.. (like always) when removing power steering....
When removing power steering pump.. i can take out the resvoiar.. what is the hard line, running from side, and across front of car.. i can take out correct?
Old Jan 18, 2003 | 08:56 AM
done's Avatar
Default Re: help quick.. (like always) when removing power steering.... (Jordo)
ok, i asnwer that question myself.... How do you take out the clips holding the high pressure lines..?
Old Jan 18, 2003 | 11:04 AM
Padawan's Avatar
Darth ModerVader
Default Re: help quick.. (Jordo)
I'm not certain which clips you're referring to, but when I removed mine, everything basically snapped out or unbolted. HTH a little.
Old Jan 18, 2003 | 11:59 AM
done's Avatar
Default Re: help quick.. (Padawan)
thanx, im gonna go to a napa, hopefuly find a fitting that will fit in the rack.. so i can loop it
Old Jan 18, 2003 | 12:07 PM
sackdz's Avatar
The thread is M14 x 1.5 You will also likely need a barbed fitting as well. I went to Napa and they didn't have it. Well they did, but the hole was way too small. Home Depot only has SAE fittings.
Old Jan 18, 2003 | 03:24 PM
done's Avatar
Default Re: help quick.. (sackdz)
aight ill try home depot monday..
Old Jan 20, 2003 | 04:42 PM
cademan's Avatar
Stupid questoin, whats a barbed fitting
Old Jan 20, 2003 | 05:39 PM
sackdz's Avatar
They won't have it
SAE = Not metric aka standard i.e. inches. You're looking for metric fittings. I got mine from http://www.hosenow.com per Dropspeed's post.
A barbed fitting is one which fits snuggly inside a tube or hose.
[Modified by sackdz, 10:00 PM 1/20/2003]
Old Jan 20, 2003 | 06:42 PM
done's Avatar
thanx bro, sackz i got a 1/4 barbed fitting to fit in it, fit perfect
Old Jan 20, 2003 | 08:17 PM
turbosol's Avatar
I use a 3/8 nylon barbed fitting with a little hondabond on it. The threads were close enough and since it was plastic the fitting would go before the threads on my rack would. Its not like its under pressure anymore. I've also converted back to stock with no problems.
Old Jan 21, 2003 | 07:35 PM
ppihctyper's Avatar
Don't throw away your power steering pump and accessories, you may need them later!!! From someone who relizes that it's ggod to keep stock items around!
dc2chris
Feb 13, 2007 10:53 AM
Hockey27925
Mar 25, 2005 10:38 AM
majormaster01
Feb 22, 2005 10:12 PM
highschooler
Aug 3, 2004 05:01 AM
1.8EG-T
Aug 8, 2002 11:28 PM
