hesitation and no power $@(
set up
89 civic Si
D16Z6
HOME MADE TURBO
DSM 14B turbo
2.75 inch downpipe
3 inch exhaust
2 inch charge pipe
DSM BOV
2 steps colder plugs and retarded 4 degree timing.
Starion fMIC
file to fit Map limiter chip
DSM 450's
still runnin stock ECU
anyways the car was up and running and running good for a few days. It had a problem with some hesitation and jumpy idle and i found the radiator cap leaking fluids. I filled the radiator back up, capped it, and i shook the DIY maplimiter and the car studdered, so i figured i had a bad connection. I then soldered all the connections and i foudn the car to run a bit lean so i adjusted the map limiter to give in more fuel. It was running great, then later on in the evening my buddy took the car out and foudn the car had even worse hesitation and no power up top.
what could be the culprite??
when the idle was jumpy and the car had some hestitation it still was relaly quick after 4K RPM it just surged n pulled.
but now it doestn do that and it has all the same symptoms.
the cars runnign lean with DSM 450's and file to fits chip. how is that possible?? i Took off the vaccum to the stock FPR to get a lil more fuel pressure but it really ran with no power.
could it be a bad FPR ???
89 civic Si
D16Z6
HOME MADE TURBO
DSM 14B turbo
2.75 inch downpipe
3 inch exhaust
2 inch charge pipe
DSM BOV
Starion fMIC
DSM 450's
[Modified by UberTeg, 1:30 AM 1/18/2003]
set up
89 civic Si
D16Z6
HOME MADE TURBO
DSM 14B turbo
2.75 inch downpipe
3 inch exhaust
2 inch charge pipe
DSM BOV
Starion fMIC
DSM 450's
89 civic Si
D16Z6
HOME MADE TURBO
DSM 14B turbo
2.75 inch downpipe
3 inch exhaust
2 inch charge pipe
DSM BOV
Starion fMIC
DSM 450's
problem solved, bad set of spark plugs, replaced it and it ran good,
i decided to play with the cam gear and advanced it 3 degrees now it pulls liek a bat outta hell, hung with an NSX which was cool.
T-RO
Nov 27, 2006 02:24 PM
move_right
Feb 8, 2003 11:37 AM
