AEM V2 Intake . . .
Old Jan 17, 2003 | 06:23 AM
Jet Phi's Avatar
Default AEM V2 Intake . . .
does anyone have any information on the new AEM intake ?
i'm considering in buying it soon . . .
but do yoo guys recommend any other good intakes for a 99 Si ?
somewhere in the $150-$250 range . . .
thanx alot
Old Jan 17, 2003 | 06:25 AM
Spade's Avatar
Default Re: AEM V2 Intake . . . (The Honda Civic Si)
AEM Cold Air Intake for the Type R. It's 3 inches in diameter.
CivicTuneR95's Avatar
ICEman For the B18c5 Teggy, Sounds Absolutly un godly on B series, and I beleive out preformed every one.
Old Jan 17, 2003 | 06:28 AM
Jet Phi's Avatar
Default Re: AEM V2 Intake . . . (Spade)
i don't get what yoo're saying
Old Jan 17, 2003 | 06:59 AM
The ITR intake piping is 3" rather then 2.5" bigger = better
Old Jan 17, 2003 | 07:00 AM
BLK JDM's Avatar
The AEM Intake piping for the Type R Integra is 3" which is larger than the AEM Intake Piping for the Si which is 2.5". It should increase you're performance but I don't know. AEM tests a lot of different size piping for optimal hp so the 2.5" piping for the Si may be ideal for your Si instead of the Type R intake.
Default Re: AEM V2 Intake . . . (CivicTuneR95)
GET the ICEMAN plastic owns JOO! you can even get it in a really cool EBP color
Old Jan 17, 2003 | 07:02 AM
nsxmatt's Avatar
Actually the correct diameter for a B16 is 2.75. The 2.5 is for the sohc motors and the 3" is for the Type R and Prelude.
Old Jan 17, 2003 | 07:19 AM
Jet Phi's Avatar
Default Re: AEM V2 Intake . . . (nsxmatt)
so the ITR intake would fit in the Si throttle ?
Old Jan 17, 2003 | 09:45 AM
nsxmatt's Avatar
If your running the stock SI intake manifold and TB I wouldn't worry about the Type R AEM intake. The 2.75 intake was made to work with the SI engine that's why AEM made it 2.75 instead of 3.0. I don't think you will see any power increase with a intake larger than the TB unless you plan to upgrade later.
k20o2o4civic
Feb 14, 2007 12:15 PM
07 4DR Si
Honda Civic (2006 - 2015)
Jan 21, 2007 12:10 PM
gsr0103
Aug 27, 2006 12:02 AM
BerlinAp2
Jun 24, 2003 10:21 AM
gsr stuie
Mar 16, 2002 11:56 AM
