wirring diagram
Old Jan 17, 2003 | 01:37 AM
Acclude's Avatar
Default wirring diagram
can any 1 tell me where i can find ecu diagram,pin outs 4 94 vti accord (f22b)
Old Jan 17, 2003 | 04:55 AM
Stew Pidasso's Avatar
Default Re: wirring diagram (Acclude)
They're not perfect but they're close.
http://www.apexi-usa.com/productdocu...onics_vafc.pdf
http://www.apexi-usa.com/productdocu...afc_update.pdf
I don't remember who posted this originally because it was in my notepad but...
"OK. All of these will be looking at the wires with the connectors in the
> ecu. The top will be the part with the push tab.
> The Red and orange both go to the yel/blk wire on the 32 P connector #11 top
> right corner.
> The Blk and Brn both go to the Blk wire just to the left of the #11 above.
> Note the Brn wire needs to be closer to the ECU.
> The Grn wire goes to the 32P connector Yel/Grn Wire #20. This is down one
> row and left 3 columns. It should be the one with nothing in the row above
> it (an empty spot).
> The grey wire goes to the 16P connector (the smallest) Red/Blk wire. In the
> top row all the way to the left.
> The Blue wire is not used
> The pink wire goes on the car side of the cut 32P connector #8 Grn/Yel wire.
> Its the wire two to the left of the Blk wire for the ground. The Purple
> wire goes on the ecu side of the same wire. Make sure they dont connect
> bypassing the VAFC.
> The White wire goes on the car side of the cut MAP sensor wire. This is on
> the 16P connector white/yellow wire two wires to the left of the Throttle
> Positioning Wire. The ecu side of the cut wire should get the yellow wire
> from the VAFC."
The only thing that is different is that the blue wire is in fact connected to the VTM wire on the ecu (Car side I believe)
e jay one
26
Sep 28, 2006 12:44 PM
B18OnTop
Oct 12, 2004 11:29 PM
Sketch_hs
Aug 19, 2004 08:44 AM
T25 civic
Oct 6, 2002 02:11 PM
Pro-Lude
Aug 22, 2001 08:41 PM
