idle problem
Old Jan 16, 2003 | 08:34 PM
88turdbucket's Avatar
Default idle problem
my 88 crx si when i start it and let it warm to operating temp.. it starts at about 700 rpm and then jumpsto 1500 rpm and then drops and then raises and so on and so on what could it be any help would be nice
Old Jan 17, 2003 | 05:35 AM
tpr's Avatar
tpr
Default Re: idle problem (88turdbucket)
Probably need to set your Idle speed. With the car warmed up disconnect the idle control solenoid (back of intake) electrical connector. Using the idle speed screw top left of throttle body when looking from the passengers side of the car set the warm idle to 750 RPM. Reconnect the idle control soleniod and see if it fixes the problem. You may need to shut it down and restart before the check engine light will go out. If this does not fix the problem then its most likely a vacuum leak. Spray carb cleaner around the intake. When the idle speed changes then you have found the leak.
Old Jan 17, 2003 | 06:28 AM
ATS_Antone's Avatar
Default Re: idle problem (tpr)
good advice.
Old Jan 17, 2003 | 07:54 PM
90da's Avatar
Did you check the coolant???? If it is low the idle would surge.
Old Jan 17, 2003 | 08:07 PM
Ben Ogle's Avatar
Default Re: idle problem (90ef)
http://www.g2ic.com/forums/showthrea...threadid=42969
I had the same problem.
Ben
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
Nisif
Nov 26, 2011 07:22 PM
FEAR6655
Apr 9, 2011 12:47 AM
OverBoostDemon
Nov 4, 2009 02:55 AM
ge_itr
Oct 16, 2007 05:12 PM
