98Accord Pwr Windows & Locks Problem
Locks don't work. Windows will only work at their door switch, not the driver panel. Replaced Master Control Unit. Fuses good. HELP!!! I don't want to take her to the dealer...Also have re-occuring code 10, IATemp, replaced sensor 2 times, no codes if I run a 3.9K ohm resistor, but runs like **** in winter. Thank you all.
Nope. Bought her new. And I've seen this problem on HondaAccord.com but nobody posted a fix for the window/lock problem. I now see that the wiring runs through both computers. Wondering if I should try replacing the drivers side one?
try resetting the multiplex by moving your wiper delay from the slow position to the fast position end then back to the middle with the key on.
god just reached out and touched Adam...
tormont
Dec 1, 2010 08:44 PM
