did swap 2 95 cx & its not running right
Old Jan 15, 2003 | 07:38 PM
Sinisterh22a's Avatar
Default did swap 2 95 cx & its not running right
have a 95 cx with 00 gsr swap and it wont rev past 7100 and no matter what ecu goes in it it all does the same thing i have done the search and i know this topic has been coverd before but i just cant seem sot find it now. both exhaust and intake vtec turn on and i am not getting a cel. could it be a coil starting to go bad or maybe just some bad wiring? any and all info would be great
Old Jan 15, 2003 | 07:47 PM
EK MONEY's Avatar
Default Re: did swap 2 95 cx & its not running right (Sinisterh22a)
what engine codes are you throwing?
Old Jan 15, 2003 | 07:49 PM
Default Re: did swap 2 95 cx & its not running right (Peagreenhatch)
none
Old Jan 15, 2003 | 08:35 PM
EGsex's Avatar
7100 red line, isnt that LS'??....wat ecu you running with??...as far of gettin ur vtec, i think u gotta re-wire the vtec thats if ur using ur cx harness ....
Old Jan 16, 2003 | 03:14 PM
Default Re: did swap 2 95 cx & its not running right (EGsex)
using gsr ecu and vtec works just fine ran all the wires and everything
Old Jan 16, 2003 | 03:17 PM
ttt
Old Jan 16, 2003 | 03:29 PM
BeerBaron105's Avatar
maybe ur fuel pump is crapping out or its clogged with crap, does it stutter as it approaches the "7100 rpm redline"?
Old Jan 16, 2003 | 04:47 PM
MADEinJAPAN's Avatar
Default Re: did swap 2 95 cx & its not running right (BeerBaron105)
check youre fuel filter
Old Jan 16, 2003 | 04:53 PM
rathead's Avatar
Default Re: did swap 2 95 cx & its not running right (MADEinJAPAN)
recheck all your wiring. do you have a svafc?
Old Jan 16, 2003 | 05:02 PM
tominos's Avatar
Default Re: did swap 2 95 cx & its not running right (rathead-ek)
what does it do at 7100, you say it doesn't go past it. is it a rev limiter or does the engine act funny?
Old Jan 16, 2003 | 07:05 PM
does not stutter it pulls hard all the way then hits rev limit
Old Jan 16, 2003 | 07:06 PM
running stock gsr ecu and thats it
Old Jan 16, 2003 | 07:07 PM
Default Re: did swap 2 95 cx & its not running right (tominos)
nope pulls hard the whole way
Old Jan 16, 2003 | 07:17 PM
just changed distribiter and coil and thats not it, it just feels like all of a sudden there isa rev limit at 7100, mdoes not sputter vtec works fine and tryed 14 ecus already same thing with all of them
Old Jan 16, 2003 | 08:09 PM
DOHCtorTHRUST's Avatar
try checking the o2 sensor, my buddy ran a race header with a screwed up o2 sensor and he redlined at 7k also... if the o2 is faulty it send mixed codes to the ECU
Old Jan 16, 2003 | 08:38 PM
ColdAccord's Avatar
Default Re: did swap 2 95 cx & its not running right (DOHCtorTHRUST)
when my accord was throwing a code for primary o2 it displated it fine. just go get a diagnostic scan, figure out what the deal is
Old Jan 19, 2003 | 08:08 AM
i think my sensors are fine i think its the guage cluster i switched them out and it reved to 9 but that cluster was off so i stuck a autometer in and hid it so it wouldnt look rider and it revs till 8 wich is about right for a gsr motor anyway i am takingit to the track to get a base run bone stock cx hatch with bone stock gsr swap even stock cx exhaust
StatGSR
Oct 11, 2003 06:11 PM
roydogg
Aug 4, 2003 10:15 AM
lonefuzzy79
12
Sep 3, 2002 01:58 PM
95cx
May 30, 2002 12:31 PM
