valve cover torque?
dude the little silver studs on the valve cover? 50 ft lbs will bust em OFF! 18 ft lb is the proper spec. I trq'd mine to like 19 and the lil bastard broke off! 50 is way to tight for the little silver studs on the valvecover. hope its not to late....
Blaze
Blaze
yeah Blaze45 said 18 pounds too...
thanks though! im glad 2 people agreed though.
means i can probably go ahead and put it back on tomorrow. is there a gasket needed? (im fairly new at this)
50
please step away from the computer.
i just tighten them with a wrench (no specific torque), its not that important, just so you get a good seal with the gasket. about 5-10 ftlbs
Just tighten it by hand, you'll feel when its enough, it doesn't really matter, just not 50 lbs though. Only thing you really need to measure is everything under the valve cover.
my bad, if you have trq. wrench trq. em to 18. Not sure what they measure the tighting w/ but i was thinkin hp/trq when I said ft lbs. sorry. Be sure to hook up your engine ground and a new gasket will keep oil from leaking out.
Good Luck
Good Luck
as tight as you can get em with 2 fingers is my rule...unless your hopped up on roids
...yea i always thought it was 7lbs. too
[Modified by wuhungsixxx, 8:09 AM 1/16/2003]
AndThenYouSay
Jan 18, 2010 05:19 PM
acmoc
Jul 3, 2008 05:39 PM
