Please guide me on this purchase...
Old Jan 15, 2003 | 03:07 PM
Goldfingiz's Avatar
Default Please guide me on this purchase...
Hey guys, I'm going to check out a 1995 Integra LS motor on Friday. I've never purchased a motor before. If there's any advice you have, i'd GREATLY appreciate it. Anything I should look for? Supposedly it only has 45k on it.
Any, and all help is very much appreciated!
Thanks,
Goldfingiz
Old Jan 15, 2003 | 03:38 PM
tominos's Avatar
Default Re: Please guide me on this purchase... (Goldfingiz)
check the oil, see if it's fresh and you can smell it. if it's not fresh, prolly been sitting there for a while. compression and leakdown test is always good. have him run it for you if at all possible.
Old Jan 16, 2003 | 08:52 AM
Goldfingiz's Avatar
Default Re: Please guide me on this purchase... (tominos)
Hey thanks tominos Only problem is it's out of the car...this is why I'm a little nervous.
Goldfingiz
Old Jan 16, 2003 | 08:53 AM
Spade's Avatar
They should have it on an engine mount so you can test it. If not walk away.
[Modified by Spade, 9:54 AM 1/16/2003]
Old Jan 17, 2003 | 02:37 PM
Goldfingiz's Avatar
Default Re: Please guide me on this purchase... (Spade)
It's sitting in his garage =\
Goldfingiz
Old Jan 17, 2003 | 03:02 PM
Atomic 1320's Avatar
Have him pull the valve cover off. If he is willing the oil pan also. If this is posable. Check for excesive wear or "slugy" oil.
Old Jan 17, 2003 | 03:21 PM
altoid's Avatar
Default Re: Please guide me on this purchase... (Atomic 1320)
if hes not compliant, because there is no reason not to be, don't take it, if he won't do it, ask if you can...if you can check for excessive wear on the cam lobes as well
Old Jan 17, 2003 | 04:16 PM
Goldfingiz's Avatar
Default Re: Please guide me on this purchase... (altoid)
Thanks guys, I'll pull the valve cover...what would 'excessive wear' look like?
Thanks,
Goldfingiz
Old Jan 17, 2003 | 04:23 PM
Blaze45's Avatar
Brrraaaap!
the lobes should look smooth and look for chaifing = damaged.
pull the cap off the dizzy and look @ the rotor and check out the plugs.
ask for his maintence records if he has any.
Good Luck
Blaze
CoolFoolIT
42
Jan 19, 2012 09:23 PM
izzyaccord
Apr 21, 2011 02:13 PM
hfcrx88
23
Apr 21, 2009 06:55 AM
B18PoweredCivic
May 10, 2004 10:04 AM
