cant get ignition timing to zero
Old Jan 14, 2003 | 05:17 PM
Jockobo's Avatar
Default cant get ignition timing to zero
my cam timing is supose to be off a couple of degrees from putting the si cam in a dx motor and now i cant get ignition timing to zero. its retarded about 2-4 degrees with the distributor all the way advanced. so what do i do??? should i grind the distributor some to get it to rotate more??
Old Jan 14, 2003 | 06:03 PM
b19coupe's Avatar
Default Re: cant get ignition timing to zero (Jockobo)
Have you tried an adjustable cam gear?
Old Jan 14, 2003 | 06:54 PM
Jockobo's Avatar
Default Re: cant get ignition timing to zero (b19coupe)
no money for a cam gear, the cam timing is suppose to be off by about 2.5 degrees + or - so that's not really a big deal rite? cam gears are adjustable to like +-10 degrees and would that really jack up your ignition timing? or is it something else wrong with my car thats making the timing way off.
Old Jan 14, 2003 | 07:31 PM
b19coupe's Avatar
Your ignition timing is off because your cam timing is off. If you are not off by one full tooth on the cam timing, you need an adjustable cam gear to dial in your cam timing. SI cam timing is set at the mark on the rear cover at about 7 o'clock or so, as opposed to 1.5l cam timing which is set level with the head.If you are not sure how to set your cam timing, get a Helms.
[Modified by b19coupe, 8:32 PM 1/14/2003]
Old Jan 14, 2003 | 07:45 PM
Desslok's Avatar
Each degree of cam rotation is equal to 2 degrees of crank, so it will be off double what your cam timing is.
Old Jan 15, 2003 | 01:51 PM
Brohamcivics's Avatar
don't know the answer to your question but maybe you can answer mine. How in the heck did you get the Crankshaft pulley bolt off? I have been struggling with mine for two days. Please help if you can.
Old Jan 15, 2003 | 02:05 PM
EVOLMTR's Avatar
Default Re: cant get ignition timing to zero (Brohamcivics)
(don't know the answer to your question but maybe you can answer mine. How in the heck did you get the Crankshaft pulley bolt off? I have been struggling with mine for two days. Please help if you can.)
A huge impact gun. If that doesn't work you might have to torch the bolt then back it out with the impact gun. I had that problem with a friend's motor once. I had to torch the bolt.
Old Jan 15, 2003 | 02:21 PM
Default Re: cant get ignition timing to zero (EVOLMTR)
I heated it last night with a torch, and hit it with a cheapy Impact. It didn't work. Your right though I need to get a bigger Gun! I will try it . Thanks
Old Jan 15, 2003 | 10:36 PM
EVOLMTR's Avatar
[I heated it last night with a torch, and hit it with a cheapy Impact. It didn't work. Your right though I need to get a bigger Gun! I will try it . Thanks]
If that doesn't work there is a special tool you can buy that slips into the crankshaft that holds it in place. Then you use a huge *** breaker bar to untighten that bolt. Good Luck.
Old Jan 15, 2003 | 10:47 PM
Aron Parsons's Avatar
your cam timing should only be off by a tooth. actually about 1/2 tooth, but since you don't have an adjustable gear that isn't possible. Anyways, your cam timing is too far out of spec, so adjust that and your ignition timing should line up as well.
Old Jan 16, 2003 | 11:46 AM
Jockobo's Avatar
Default Re: cant get ignition timing to zero (Aron Parsons)
alrite thanks for the replies
Old Jan 23, 2003 | 03:48 PM
pornstarSR's Avatar
your gona need an adjustable cam gear....or try to find out how many degrees it changes if you move it one tooth..... it could work
but now my question is can i put an SI cam in my DX(98 but i know 92-95 dx cam grind fits and run in it).....i have heard conflicting stories....
but webcam has there Dx cam and Si cams in the same cam section.....
Red_Si
Apr 20, 2004 07:21 PM
has-t
Jul 1, 2003 09:58 AM
Mr.Integra
May 22, 2003 12:41 AM
Lazydsm
Feb 6, 2003 06:47 AM
