large cranking pressure variance
Old Jan 14, 2003 | 03:00 PM
Stewie's Avatar
Default large cranking pressure variance
I did a compression test on my 99 GS Integra. The highest # I got was 180, but the lowest # I got was 165. I'm not concerned with the actual #s, but the 15psi variance that I got between the cylinders.
I was wondering what could be the cause of the lower pressure. Is it possible that that the valves are not fully seated? When the valves are bent, is it usually very obvious meaning, would there have to be more than a 15psi loss, or is it possible that only a few pounds of pressure could be lost?
thanks
Old Jan 15, 2003 | 04:43 AM
Stewie's Avatar
Default Re: large cranking pressure variance (Mac8008)
Old Jan 15, 2003 | 08:04 AM
KingDsi's Avatar
15 psi is the limit for variance between cylinders. Your rings in that cylinder are on their farewell tour, how long they last are based on how much they are worked (taken up to high temp for long periods of time)
Old Jan 15, 2003 | 09:01 AM
Desslok's Avatar
Default Re: large cranking pressure variance (KingDsi)
I would agree with the ring theory. Was this the first time you checked it? It could have been not broken in right.
Old Jan 15, 2003 | 11:16 AM
Stewie's Avatar
Default Re: large cranking pressure variance (sp)
Thanks for the replies guys. I really wanted to know if it is possible that it could be the valves. I want to do a leakdown test soon and possibly take it up with the dealer.
thanks again
ojasia
Aug 6, 2015 02:03 PM
gotboostedvr6
Welding / Fabrication
Nov 20, 2006 03:48 PM
lke2drvgsr
Jan 11, 2004 10:02 AM
prelittlelude
May 2, 2003 07:12 AM
drumking15
May 1, 2003 02:40 PM
