Revs Drop so Low, Car Dies
Old Jan 14, 2003 | 10:15 AM
Comptech98GSR's Avatar
Default Revs Drop so Low, Car Dies
This has been happening for sometime now, but it has occured more lately. When i'm in a parking lot, or driving slow in an area, once i push the clutch in, after moving, the revs will drop so low, the car will die on me. Anyone had this problem, or what the cause could be.
Old Jan 14, 2003 | 10:16 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Revs Drop so Low, Car Dies (Comptech98GSR)
mine does it every so often. something with the ignition most likely
Old Jan 14, 2003 | 10:27 AM
Default Re: Revs Drop so Low, Car Dies (rewsnaeht)
i've almost replaced everything there is to, on ignition, except coil, cap,and rotor, maybe i will try replacing those ,and seeing, if it help. any other suggestions.
Old Jan 14, 2003 | 10:44 AM
EL Vap133's Avatar
Does the car kinda hesitate at WOT?
Old Jan 14, 2003 | 10:51 AM
Default Re: Revs Drop so Low, Car Dies (Vap133)
not very often, but it will occassionally
Old Jan 14, 2003 | 11:18 AM
neo1z's Avatar
by the look of that 1/4 mile time, it doesnt seem to be hesitating too much...
Old Jan 14, 2003 | 11:40 AM
samagon's Avatar
plugs, cap, rotor, wire, coil, air filter.
any one of these things, or all of them.
or something else entirely.
don't just throw parts at it, but if you haven't had it tuned up in a long time, get that done, and then go from there.
Old Jan 14, 2003 | 07:26 PM
stumpyf4's Avatar
Default Re: Revs Drop so Low, Car Dies (samagon)
clean the throttle body, i predict that it's very dirty.
Old Jan 14, 2003 | 10:02 PM
GoldenONE's Avatar
did you change the settings on your cam gears? mine died too after i changed the settings on the gears. that might be the problem
Old Jan 15, 2003 | 03:01 AM
B00ST2nR's Avatar
Default Re: Revs Drop so Low, Car Dies (EAD Boostin Dc2)
Mine did that after getting my Cams, Cam Gears, FPR, and VAFC installed.
After the settings of the Cam Gears were changed, my car started dying on me during Idle. Fixed it by leaning out the bottom with my VAFC. Doesn't die anymore and runs smoothly.
Also, check your Spark Plugs. That might be it.
Old Jan 15, 2003 | 07:22 AM
Default Re: Revs Drop so Low, Car Dies (Skunk2nR)
yes i did change my cam gear settings, but it was a while ago, and it didn't do it , right after i changed them or anything..
Old Jan 15, 2003 | 08:19 AM
LsPower's Avatar
This was happening to someone I know it was his idle control sensor
Old Jan 15, 2003 | 08:21 AM
arw321's Avatar
Skunk2nR, how much did you lean your fuel out (with your vafc) to solve this problem?
Thanks,
Adam
Old Jan 15, 2003 | 08:46 AM
Goldfingiz's Avatar
Default Re: Revs Drop so Low, Car Dies (arw321)
Check your compression =\
Goldfingiz
JoHA
Jun 9, 2008 07:50 AM
b16bri
Apr 21, 2008 12:47 PM
HNDAPWR
13
May 25, 2004 04:00 AM
sohc_boy
12
Jul 29, 2003 04:24 AM
carcala
Jun 6, 2002 09:53 PM
