Major problems, please help out, guys !!!
I had 91 CrX and the problem is no electrical at all when I turn the ignition on, no thing come out, no light, nothings. I change the new battery, headlight, signal, brake light working fine, but all the light in tach don't work. What do you think ? Any suggestions ? Please help out, guys !
Thanks alot .
[Modified by superslowhatch, 7:18 PM 1/12/2003]
Thanks alot .
I got in a wreck once and the same thing you described happened to me too. It turned out that I had knocked several fuses out underneath the hood. Check your fuses carefully too because some of mine actually blew.
Thanks alot .
Thanks alot .
your Ignition switch may be going out, or it may have come unplugged.
Something else to check if all of the fuses are good.
All right, guys !
I changed out the Ignition, I turn the key on, everything work fine now, but there's a problem. I couldn't start the car, when I started it, I heard the sound click...click under stereo. So, I take out the center console and I found there is a relay, kind a small. That relay click when every time I started. I checked all the fuse, all fine. I push the clutch all the way down, still not start the car, I heard NO sound from the starter. What do you guys think it is ? Broken starter circut, starter relay bad ? Any commend ???? Please help out.
Thanks a lot , guys .
hahaha maybe something stupid , like what happened to me.. there is a wire that goes to starter you can look down from the engine bay it just plugs in... well i drove to a local store and parked my car everything worked fine then i came out and turned key on had the problem you had (turn key no sound from starter) and noticed that plug with the rubber boot was off the alternator so i was like wtf?? i push started my car in parking lot at store hahah and drove home popped hood to uninstall starter to go replace it and boom while doing that the wire was off and i was like i didnt take this **** off.. so i plugged it in and turned key and car turned on, saved me the time of tking it off and going to store to get one!!!!
*not everyone is as fortunate as me.
airmech07
Honda Civic (2006 - 2015)
Jun 5, 2010 11:30 PM
