gsr clicks when attempting to start??help??
Old Jan 12, 2003 | 12:20 PM
darrinbrewer's Avatar
Default gsr clicks when attempting to start??help??
is it the starter solonoid? my truck did this and that fixed it.. but i hear the click in the left of the dash -when i turn the key and hold it --the click starts and when i let go of the key the click ends -just one click --kinda like this -- turn key"cli..."let go of key -"..ick.."
Old Jan 12, 2003 | 01:32 PM
rated_r's Avatar
Default Re: gsr clicks when attempting to start??help?? (darrinbrewer)
starter
rated_r's Avatar
Default Re: gsr clicks when attempting to start??help?? (rated_r)
did u check the fueses......
Old Jan 12, 2003 | 02:05 PM
Rory Breaker's Avatar
Check your ECU fuse.
Old Jan 12, 2003 | 02:07 PM
it doesn't do it all the time -just periodically ..mostly on the first start of the day, but today at the gas pump, took like 15 turns of the key to start.
Old Jan 12, 2003 | 02:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
a click in the fashion you described sounds like a relay clicking on and off. I'm not sure what it could be, though.
Old Jan 12, 2003 | 02:17 PM
h23vtec_dc2's Avatar
Default Re: gsr clicks when attempting to start??help?? (PatrickGSR94)
could be your starter or your battery connection is probably bad.. try moving it around and all.. happened to my integra. one of my friends civic died, it just clicks, and when i got there i went straight to the battery and moved it so it gets a good connection and the car started.. let me know how it goes..
Old Jan 12, 2003 | 04:24 PM
speedymon's Avatar
Default Re: gsr clicks when attempting to start??help?? (mugenb18c)
Same thing happened to me. Try out his suggestion.
Old Jan 12, 2003 | 06:09 PM
ronin's Avatar
Default Re: gsr clicks when attempting to start??help?? (speedymon)
clean your battery terminals and tighten your cables
Old Jan 13, 2003 | 06:27 PM
Default Re: gsr clicks when attempting to start??help?? (ronin)
positivie battery termainal had like a 5lbs of corrosion - so i cleaned it off with a toothbrush --wait and see how it does i guess..
Old Jan 13, 2003 | 06:48 PM
GSRaCeRbOI's Avatar
check your battery terminals and check the grounds (the ground from the batt to the chassis and the ground on the valve cover, etc) and make sure all the connections are good and tight... if its "clicking" the starter solenoid should be working.. when my battery was REALLY low it would click and dim all the instrument panel lights but not start (I left the car in the garage w/ the alarm on and went on vacation ) after trickle charging the battery it started right up..
when the starter died it did the same.. I would turn the key.. it would click but not crank over.... this time it was the starter for me...
Old Jan 13, 2003 | 06:58 PM
michaelpr's Avatar
New User
Default Re: gsr clicks when attempting to start??help?? (GSRaCeRbOI)
Yes, it is either the battery or the starter. First work with the battery - the relay is getting current, but is not passing enough to start the car. First check the connections - like you did. Then check your battery condition and age. Check to see if the alternator is charging it properly. See if the battery is holding charge.
Old Jan 13, 2003 | 07:14 PM
Brian-Brian
Guest
Posts: n/a
im pretty sure is the battery same thing happen to me.... take your battery out and bring it to the auto shop so they could test it .... good luck
Old Jan 13, 2003 | 09:49 PM
Volcom's Avatar
Default Re: gsr clicks when attempting to start??help?? (Spoon_b18)
I had the exact same problem. I just got done putting the motor back in the car after a clutch, water pump, and timing belt install and decided to replace the starter since I was in there. No problems now.
inaety
Jun 24, 2011 12:57 AM
FSS13foxtrot
Apr 1, 2008 08:05 PM
IIXtremeHansen
24
Jun 11, 2007 10:28 AM
Fatboy1985
Dec 26, 2003 02:38 AM
jolt-tsp
Oct 31, 2003 04:17 PM
