spoon drain plugs.. where to put transmission?
Old Jan 12, 2003 | 11:06 AM
d8168055's Avatar
Default spoon drain plugs.. where to put transmission?
2 questions... the one w/ the shorter magnet is what im talking about...
1. where does it go?
2. i took off the big nut to the right of the axel and some transmission fluid leaked out... is this ok? the manual says its enough when u can stick ur finger and feel it on the bottom of the hole...
thanks all
Old Jan 12, 2003 | 11:10 AM
uNF$@#!'s Avatar
Default Re: spoon drain plugs.. where to put transmission? (d8168055)
both go in the drain plugs.
MackSpeed-616's Avatar
yeah that should be it
Old Jan 12, 2003 | 11:13 AM
d8168055's Avatar
Default Re: spoon drain plugs.. where to put transmission? (BustaNutt-616)
where does the short one go? i tried to put it in the one to the right of the axle, but the hole is too big
Old Jan 12, 2003 | 11:23 AM
Tommy_Gunns's Avatar
It goes on the drain plug on the tranny. The drain plug on the tranny is round with a square hole. It should be located lower right to the fill plug that you have found.
Old Jan 12, 2003 | 11:32 AM
d8168055's Avatar
Default Re: spoon drain plugs.. where to put transmission? (Tommy_Gunns)
so , i guess the blue circle? how do i take that off?
Old Jan 12, 2003 | 11:41 AM
yep...that's the one
just stick your 3/8" driver in there (without a socket).
Old Jan 12, 2003 | 11:47 AM
d8168055's Avatar
ok cool, thas what i thought... but now the 2nd question... while doing this i lost some fluid. When i open the bolt in the yellow circle, it still drips out some fluid... is this adequate? the manual says it should be on the lower level of that hole
Old Jan 12, 2003 | 11:51 AM
When you go to unbolt the drain plug...all of the fluid will come rushing out. My suggestion is to replace with new fluid. Make sure your car is leveled and pour fluid into the tranny (fill hole) until it is at the fill hole height (it will start leaking out...wait till it stops leaking and put the fill plug back on).
Good luck!
Old Jan 12, 2003 | 11:54 AM
d8168055's Avatar
its is leaking out... so is that enough? i dont have any MTF on me... i did the swap as quick as i can (changeing the drain bolts)...
Old Jan 12, 2003 | 11:56 AM
Personally, I wouldn't have changed the plugs without changing the fluids.
If your car is leveled and it is pouring out of the fill plug then that is enough.
-Tommy who changes his tranny fluid 3-4 times per year.
Old Jan 12, 2003 | 11:59 AM
d8168055's Avatar
well, its not exacly level... i jacked it up on the passenger side with a jack in the front center...
Old Jan 12, 2003 | 01:38 PM
Reid's Avatar
Global Moderator
Don't be lazy.
Change your oil and trans fluid.
Old Jan 12, 2003 | 04:36 PM
B2FiNiTY's Avatar
Dude, raise your car so that it is level all the way around. Spend $10 and change your fluid. Don't do things half azzed
Old Jan 12, 2003 | 04:39 PM
jonas's Avatar
Default Re: spoon drain plugs.. where to put transmission? (B2FiNiTY)
$35 or so on drain plugs and you can't fork over a bit more for fluids?
northkai3
26
Sep 29, 2013 11:53 AM
nubs
Dec 15, 2004 02:14 PM
R Thizzel
14
Sep 20, 2004 06:16 PM
The Internet Tough Guy
Nov 1, 2003 12:37 PM
B2FiNiTY
Dec 19, 2001 08:54 PM
