removed transmission drain plug - and threads on tranny came out with it???
Old 10-31-2003, 10:26 PM
The Internet Tough Guy's Avatar
Default removed transmission drain plug - and threads on tranny came out with it???
i hate my tranny - and i think it hates me more.
today, i was gonna change the fluid. i jacked the car up, and started to remove the drain plug: i cracked the bolt, and loosened it the rest of the way by hand. the bolt hit the ground, and all the fluid poured out.
after the fluid finished draining, i picked up the drain plug off the ground, and noticed that it's threads were filled with aluminium from the transmission's casing!!! wtf???
has anyone else had this happen to them?? why?????? talked to a honda-tech and he said that if the last person to change the fluid overtighetened the bolt, it may have stripped the casing's threads.
argh what should i do? re-tap it, get another casing, or... get a new tranny?
Old 11-01-2003, 07:11 AM
goodbyegti's Avatar
yeah sounds like the person who changed the fluid before you could have cross threaded the drain plug.. re-tap sounds like a good plan...worth a try before you start removing the tranny to replace the housing etc..
Old 11-01-2003, 07:27 AM
DCStreetHtch's Avatar
Default Re: (goodbyegti)
thats a buzz kill, re-tap should be first on the agenda.
-Bryan-
Old 11-01-2003, 12:29 PM
Default Re: (EGStreetHtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGStreetHtch &raquo;</TD></TR><TR><TD CLASS="quote">thats a buzz kill, re-tap should be first on the agenda.
-Bryan-</TD></TR></TABLE>
yep. ruined my weekend. talked to someone else, and he said that it was might have been a threaded insert that ripped out. so, someone stripped it before, then fixed it but did a shitty job.
are cx/dx/lx tranny casings the same as ex? if so, i might be interested in getting one for cheap and swapping the casing. pm me if you have one, or just the casing lying around.
Old 11-01-2003, 12:37 PM
JV
Who?
JV's Avatar
Default Re: removed transmission drain plug - and threads on tranny came out with it??? (jwn7)
I have 2 D series trannies forsale.
https://honda-tech.com/zerothread?id=663216
northkai3
26
09-29-2013 11:53 AM
JASIYAH6
03-09-2009 10:05 AM
eg_gsr11
16
02-05-2006 10:22 PM
4doorLX
10-02-2002 10:55 AM
tweekerz
05-09-2002 11:22 AM
Quick Reply: removed transmission drain plug - and threads on tranny came out with it???
