car won't start after completing AUTO TO MANUAL swap!!
Old Jan 11, 2003 | 01:15 PM
carsaregood's Avatar
Default car won't start after completing AUTO TO MANUAL swap!!
Well me and my friend have been working on his '96 LS integra, and as far as i know, everything looks good. There are a few plugs left over from the automatic wiring harness that i'm not too sure about, as well as 2 plugs on the clutch pedal that are unused. I think they are for overriding the neutral lock. but since there don't appear to be anything to plug into them, we've left them unplugged.
the car has power, but the starter won't kick out and do its thing. can anyone with experience with this conversion help? we're about to try to push start it just to make sure it starts and runs properly, but we'd like to solve this issue very soon.
There is also a little white box that got replaced by the new (manual) clutch pedal. it says mitsuba inter lock. we plugged that in, and still it wouldn't start, but it also wouldn't let us take the key out of the ignition. i am wondering if we need to have that plugged in or not.
so to summarize... do we need to do something about the 2 plugs on the clutch pedal? does that white box need to be plugged in?
Old Jan 11, 2003 | 01:19 PM
cock head's Avatar
Default Re: car won't start after completing AUTO TO MANUAL swap!! (carsaregood)
Sorry to ask a stupid question what ecu are you using?
Old Jan 11, 2003 | 01:22 PM
Default Re: car won't start after completing AUTO TO MANUAL swap!! (therumblingteg)
thanks for the quick reply!
ecu is a '96 ls manual. as far as the obd stuff and general compatibility of electronics is concerned, i know nothing. but i'm pretty sure that this ecu should work.
EDIT: '98, not '96, my mistake
[Modified by carsaregood, 11:41 PM 1/11/2003]
Old Jan 11, 2003 | 01:28 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Make sure you have the clutch start switch, make sure it's plugged in, and make sure it's properly adjusted. If just want to test it to see if the car will start, you can just push the switch with your finger and try to see if the starter will crank. If the switch is not pressed, no power will go to the starter.
Old Jan 11, 2003 | 01:36 PM
Default Re: car won't start after completing AUTO TO MANUAL swap!! (PatrickGSR94)
sweet, i'll try that! one thing: where is the clutch start switch? and do you know if the automatic harness has a plug for it?
Old Jan 11, 2003 | 02:05 PM
'98 manual ECU! not a '96
Old Jan 11, 2003 | 03:49 PM
jeebusm3's Avatar
Gotta be the clutch start. On mine, if the cluctch isn't pressed all the way down the car doesn't even try to start.
Old Jan 11, 2003 | 04:42 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: car won't start after completing AUTO TO MANUAL swap!! (jtrbocrx)
after you ripp out the auto there is a white slider still right ???if its still there that is your shfit indacator there is a 10ga black white that needs to be connected.(neutral safty switch bypass)then your key issue take the lower part of the steering coloum off below the key there you will find a screw in the bottom of key cylenderyou need to remove that screw and that will let you remove the key so the car dosent have to be in "park"
Yup I'm pretty confident that is it. I had that problem with my car when I did the swap.
Check it out. Good luck.
Old Jan 11, 2003 | 05:15 PM
Type Wah's Avatar
Default Re: car won't start after completing AUTO TO MANUAL swap!! (shamoo)
check the ignition fuse...
Old Jan 11, 2003 | 06:58 PM
jtrbocrx, you were so right. we got it started today by re-plugging in that slider, and setting it to "park." i'm not sure i understand this part of your post though:
"take the lower part of the steering coloum off below the key there you will find a screw in the bottom of key cylenderyou need to remove that screw and that will let you remove the key so the car dosent have to be in "park""
when you say key cylinder, is that where you put the key into the ignition? i don't really know the terminology. so if i take out that screw i can unplug that white box where the clutch pedal now resides?
thanks for all your help!!!
Old Jan 11, 2003 | 07:48 PM
SixPAK's Avatar
New User
I think he was refering to the problem you had of not being able to take the key out...and I think that it was caused by the slider thing not being set to park cause in an auto if you have the shifter in neutral you won't be able to take the key out, but now that you have set it to park, do you still have the key problem?
Old Jan 12, 2003 | 01:47 PM
Default Re: car won't start after completing AUTO TO MANUAL swap!! (SixPAK)
i do not, the key comes out. ok that makes more sense now. do you guys with auto-manual swaps just leave the slider there? or do you have a cleaner, more permanent solution?
also, the reverse lights do not work, does anyone know how to wire those in? thanks again!
[Modified by carsaregood, 10:48 PM 1/12/2003]
Old Jan 12, 2003 | 03:04 PM
BuddhaSiR's Avatar
did an auto to manual swap on a 91 integra. you have to bypass the neutral safety swich.All the wiring can be done at the shifter. On the transmission there's 2 wires that you have to run to the shifter wiring harness in order for reverse lights to work. Don't know for sure wire colors, can't help you there.
Old Jan 12, 2003 | 11:33 PM
ptsiu's Avatar
I'm planning to do the swap on my 95 teg this summer. I heard that the transmission mount for manual is different. How do you deal with that? get a manual and weld it? or it has a auto to manual tranny mount in the market? PLease advice.
Old Jan 13, 2003 | 10:52 AM
Default Re: car won't start after completing AUTO TO MANUAL swap!! (ptsiu)
yes indeed, there is a conversion mount made by Place Racing that we used. It is necessary because the manual tranny sits far lower than the auto, so its basically just stretched out.
other, factory, manual, mounts are needed as well. The right lower, the rear mount, and an "engine stiffener" were all needed, along with the corresponding bolts. A helms manual was MUCH help because the drawings are very accurate, and you can see the differences between the auto and manual.
there is a post on honda-tech that we referenced as well, by azn_flava.
https://honda-tech.com/zerothread?id=273253
https://honda-tech.com/zerothread?id=264493
i'm sure there's more info here and there on h-t.. but this pretty much covers the whole conversion. feel free to ask questions!
Old Jan 17, 2003 | 07:52 PM
Kryptonite's Avatar
this mite b a doubt question but u sure u are using a manual throttle body & ?
Old Jan 18, 2003 | 11:34 AM
Specialk's Avatar
Default Re: car won't start after completing AUTO TO MANUAL swap!! (teg turtle)
so let me get this straight, there is a way to do this swap w/o welding the manual mount in, cuz if so thats gonna save me like 400bux on labor, cuz i dont have to take it to a shop my friend(who doesnt know how to weld) can do it. please please direct me to the location where i can find this magical piece that solves my problem.
Old Jan 18, 2003 | 12:41 PM
ptsiu's Avatar
Default Re: car won't start after completing AUTO TO MANUAL swap!! (Specialk)
how much have you guys spent on the conversion? Planning to do it but worry about the budget.
cloud4571
19
Aug 3, 2013 07:06 PM
thatmexican32
Honda Civic (2001 - 2005)
Sep 27, 2010 08:43 AM
PyRo20
Transmission & Drivetrain
Aug 31, 2010 01:55 PM
ilikejesus
May 7, 2009 08:46 PM
bOOsTiNSoHcVtEc
May 29, 2003 07:57 PM
