93 honda auto to manual swap trouble
93 civic auto to manual swap -
thanks so much for your help before. but i ran into another problem. it wont start, .Everythings getting power. i haven't tried jumping the starter. because the key wont come out. so i think its some kind of relay from the auto transmission lock that wont let you take the key out, unless its in park. whould that have anything to do with it not giveing power to the starter
auto to manual swap car wont turn over
Finished swap to a manual on1993 honda ex. I put in a 1.5 with a manual tranny.
My problem is the car won't turn over I'm assumeing I need to splice a wire together
Because I can't take the key back out without disconnecting the battery I think the car thinks its in gear or something
Re: auto to manual swap car wont turn over
Well sence I have no idea what that is no. where is it located and what dose it look like? Thank you all very much for the reponce so far
Re: 93 honda auto to manual swap trouble
Wire the 2 thick black wires, that should let you start it, the on the steering colum remove any plastic covers and there should be a little white box with a screw holding it shut, take the screw out and a pin should either fall out on its own of you will have to pull it out with a flat head, that will let you take ur key out
Wow I just wanna say you guys are the best its late so I'm gonna try in the morning.
Sorry about the other topic I asked my friend for help and he posted the other one
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
Exact same principle just newer chassis. Pics and all
https://honda-tech.com/forums/showthread.php?t=1337459
ok i have it running but now the engine is moving up and down when I'm driving, the thread that Luserkid posted said to use the auto axles. i used the manual ones my only thing is the manual one driver side is shorter and went in fine. i didnt check the size of the passenger side one but they looked the same. will swapping them fix it or are they the same size
(edit) ok i looked online im pretty sure there the same size any idea what i would have done wrong to cause this the passenger side is also sitting kinda higher
(edit) when were putting the motor back in the passenger cv axle dug into the ground as we where lowering the engine in if a joint popped out or we bent it could that be causing this. its not knocking tho
yup i ordered it off ebay this is it http://outboundlink.me/ib.php?DR_id=...3Fp%3D47891337
i couldn't get it to mount with the other one. Is it possible that it is angled wrong dont think thats possible but you never know
also i used the rear mount from the manual the driver side mount from the auto busted the manual one when putting the engine back in and that conversion one i got off ebay
i drove the car down the street everything is in it just has one hell of a pull and the thing where the engine picks up and the car kinda drives funny
I am doing a transmission swap on my 93 delsol 1.5L and trying to find out what else I need but the site wont let me upload the photos I have taken. If anyone may help I can e-mail you the photos to see what else I need
Upload your pics to ImageShack, PhotoBucket, etc. Then paste the image links into your post.
HondaIsBueno
10
04-14-2008 08:14 PM
