OEM Sleeved Blocks - HP Rating
Old Jan 10, 2003 | 06:43 PM
crxhybrid1320's Avatar
Default OEM Sleeved Blocks - HP Rating
Wanted to see how much HP and Boost people have run on the OEM sleeves. Have heard of alot of people using the aftermarket sleeves like Golden Eagle or Darton sleeves.
Since I want to use the OEM sleeves can I still use the factory headgasket.
I think that for high boost you need either a o-ringed block or
o-ringed headgaket like the cometic HP gasket.
Not too much known on this topic thanks for the info
Jason
Old Jan 10, 2003 | 06:53 PM
turbohonda's Avatar
Default Re: OEM Sleeved Blocks - HP Rating (crxhybrid1320)
The stock sleeves should work up to like 450+hp (20+psi depending on setup), but if the motor detonates any it will most likely split the sleeve. I have personally seen low 400's but I am sure people have made well over 550hp. The stock head gasket should be fine with ARP head studs without any O ring or O ringed headgasket. Headgasket problems are usually caused from improper tuning. IMO
[Modified by turbohonda, 7:54 PM 1/10/2003]
Old Jan 10, 2003 | 07:17 PM
bigTom's Avatar
Default Re: OEM Sleeved Blocks - HP Rating (turbohonda)
i have witnessed over 600 on the dyno... so i know it possible
Old Jan 10, 2003 | 07:54 PM
simple4012's Avatar
New User
Default Re: OEM Sleeved Blocks - HP Rating (ek9t)
sure is
Old Jan 10, 2003 | 09:11 PM
tony1's Avatar
Default Re: OEM Sleeved Blocks - HP Rating (simple4012)
it's possible, but the slightest amount of detonation and they're gone!!
Old Jan 11, 2003 | 04:12 PM
Default Re: OEM Sleeved Blocks - HP Rating (tony1)
Well if the sleeve cracks due to too much boost or detonation will that damage the internal engine components or just need to be re-sleeved and re-ringed?
I have brand new 81 mm pistons I wanted to use these until the sleeve give out then get the aftermarket sleeves in the long run.
JAson
Old Jan 11, 2003 | 05:27 PM
Am also running a block guard if that helps!
young geezer
Dec 16, 2010 09:04 PM
hamizle
Sep 21, 2010 10:05 PM
dartonh22
Apr 27, 2008 07:31 AM
19sec beast
Jun 23, 2005 10:25 AM
PM-Performance
Nov 10, 2003 11:03 AM
