Turbo Timers - Whats out there..
Old Jan 9, 2003 | 11:52 AM
vtec.dc2's Avatar
Default Turbo Timers - Whats out there..
Blitz Turbo Timer DTT DC II:
- Boost Display (up to 36.75psi) with Peak and Hold function.
- Boost Warning. Allows the user to preset the boost warning.
- Both manual an auto settings, How it works (5 different ways):
1. Will start to calculate time automatically after 0.2HKPA. Low setting
2. Will start to calculate time automatically after 0.2HKPA while adding more time then in mode A-L. Medium setting
3. Will start to calculate time automatically after 0.1HKPA. High setting
4. Will start to calculate time according to how long the ignition has been on. Adds 55 seconds per hour.
5. Will start to calculate time according to how long the ignition has been on. Adds130 seconds per hour
Blitz Turbo Timer FATT DC II:
- Voltage Display
- Temperature Display. Monitors the cabin temperature.
- Stop Watch and Lap Timer. Allows the user to use the stop watch function and also can record up to 5 lap times.
1. Will start to calculate time automatically after 1800rpm. Low setting
2. Will start to calculate time automatically after 1200rpm. Medium setting
3. Will start to calculate time automatically after 900rpm. High setting
5. Will start to calculate time according to how long the ignition has been on. Adds130 seconds per hour.
Apex'i Turbo Timer:
- Factory O2 Sensor Display
- O2 Sensor Voltage Display
- Voltage Display
- Both manual an auto settings, How it works: Don't know details
Greddy Turbo Timer:
- Voltage Display
- Disconnected Battery Feature
- Speedometer and Parking Brake Safety feature (turns the car off if it moves or parking brake released)
- Both manual an auto settings, How it works: Estimates the driving RPM according to the vehicles alternator signal and then recommends a count down time.
HKS’ Turbo Timer Type-0:
- Voltage Display
- How it works: Don't know details, features at least auto settings
Type-1 Turbo Timer (Black - U.S. Spec):
- Voltage Display
- 1/4 Mile Acceleration Time Measurement.
- Stopwatch features for lap timing
- Engine RPM Display
these are the only brands i know of.. What I'm interested is the additional features, such as a/f reading, voltage or other. Got some of their features, if anything i missed, please reply
[Modified by vtec.dc2, 5:57 PM 1/9/2003]
[Modified by vtec.dc2, 7:49 PM 1/9/2003]
Old Jan 9, 2003 | 12:24 PM
paulzy's Avatar
Default Re: Turbo Timers - Whats out there.. (vtec.dc2)
They're basically all the same.
I have a greddy for sale...
70 shipped
Old Jan 9, 2003 | 01:42 PM
niedejb's Avatar
Default Re: Turbo Timers - Whats out there.. (1320development)
Had a run in with a bad apexi timer.
Greddy hasnt failed me yet with the same wiring.
Old Jan 9, 2003 | 01:48 PM
MiraiZ's Avatar
Apexi autotimer has everyhting you're looking for, but the A/F meter isn't accurate...just a ball park figure, but at least it gives you a decimal number instead of some pinball machine light show that the autometers give!
Old Jan 9, 2003 | 02:01 PM
vtec.dc2's Avatar
o.k. updated from manufacturers information..
1. don't know enough about how apexi and hks calculate the turn off times
2. dont know if hks allow manual mode...
3. don't know anything about new greddy turbo timer, is that the same thing as old one - or it is the new boost controller that is out?
Old Jan 9, 2003 | 02:06 PM
2000Accord5sp's Avatar
How do turbo timers work with alarms? is there a function that comes with the turbo timer that you need to look for or something on the alarms? I always wondered how the two would work together.
Old Jan 9, 2003 | 02:10 PM
GSRrR's Avatar
I had the old greddy and currently using the new one. The new one looks like it is made better. Maybe it is just me. It also has more features than the old one like lap timer and attack modes (0-100 kph, etc).
They both have safety features like the speedo and e-brake sensor which will turn the engine off if the car moves or the e-brake is released when the TT is counting down.
The new TT also changes its back-lighting (from blue to red) as warning for high speed or high voltage.
Old Jan 9, 2003 | 07:34 PM
vtec.dc2's Avatar
Default Re: Turbo Timers - Whats out there.. (GSRrR)
thanks, does anyone know if hks timers allows to set the time manually?
Mjfan12
Audio / Security / Video
Sep 19, 2005 12:31 PM
ninja8oi
Aug 8, 2004 05:22 PM
streetlvlhatch
Apr 11, 2004 08:07 AM
Audio28
Jul 13, 2003 02:18 PM
smallttocs
Feb 22, 2003 09:47 AM
