wrapping aluminum foil on o2 sensor?
my cel went on recently on the r and im running a car sound cat, i have heard if wrapping aluminum foil on o2 sensor would turn it off??anyone have experience with this?does it really work ?anyone know how much a stock cat cost?i heard $800.>?well thanks for your replys
ive had people swear it works to me.
but i had foil on my o2 sensor on my 2000 civic and it still thru a code after about 15miles or so of driving....
I have the same question. Is there anything better to wrap it with instead of aluminum foil that will last? The CEL doesn't really bother me that much, but it'd be nice if it only came up when there was an actual problem with my car.
2.25 test pipe, 14 months and counting and no CEL. And yes I wrapped my secondary tightly in aluminum foil. The foil lasts about 6 months if you drive daily and up to two years if you drive your R as often as I do. Which is twice a month at best.
so every 6 months you have to unbolt the cat and put foil into that thing?wat a hassle i hate the cel, do you wrap it tightly? okay i might try it then instead of buying another car sound since the stock one cost alot more
or is it best to change obd1?
No luck on the foil for me, but that was a civic also.
I tried to wire up the O2 Sensor "fooler" and also had no luck with that.
https://honda-tech.com/zerothread?id=221347
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-ITR-373 »</TD></TR><TR><TD CLASS="quote">No luck on the foil for me, but that was a civic also.
https://honda-tech.com/zerothread?id=221347 </TD></TR></TABLE>
The o2 sensor fooler works if you follow the instructions and wire it up correctly.
Make sure you solder all of your connections.
If you want to turn the CEL off my buddy got a 02 dummy from casper electronics it passed emissions in Illinois with the dummy and it has been on the car for 3 months 96 hatch with B16 swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Why not just buy an O2 simulator? </TD></TR></TABLE>
exactly. i've heard of some websites. search google.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
WOW! Back from the dead
</TD></TR></TABLE>WOW! Back from the dead
I had to wrap mine (1997 ITR) in foil, then in duck tape, then in a zip lock bag. Zip tied it to the shift linkage, and had one occurrance of it in the 2 years I ran it that way. All I had to do at that time was rewrap it.
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">o2 simulators are cheap these days...go that route.</TD></TR></TABLE>
either buy one or make one out of a o2 sensor + radio shack...$10.
98savage
May 15, 2007 10:33 PM
fredtoast
May 9, 2003 05:41 PM
