jdm ITR in a hatch
Old Jan 8, 2003 | 11:27 PM
95integragsr1984's Avatar
Default jdm ITR in a hatch
when i install the jdm itr motor in my hatch it will come with a jdm 4-1 header right?? if so will to reach the stock cat on the hatch?will i need to get a different cat, if so which one should i get that will fit?also will a stock itr exaust fit on a 94 hatch?
thanks,Randy
Old Jan 9, 2003 | 04:22 AM
Noe Kozz's Avatar
Default Re: jdm ITR in a hatch (95integragsr1984)
A jdm 4-1 header should come along with the motor. I believe the ITR header will reach your stock cat, since it's a little longer than say a GSR. A stock ITR exhaust could fit in your 94 hatch with some minor tweaking. Hope that helped you some.
Old Jan 9, 2003 | 04:52 AM
Plan B's Avatar
Default Re: jdm ITR in a hatch (VTEK 4 U)
Pay about $125 and get a carsound cat made that will bolt up to your stock exhaust.
If you get it, swap the itr cat over to the civic, that will work too.
Old Jan 9, 2003 | 06:33 AM
4g4me's Avatar
The header that you will get depends on the year ITR it is comming from.
Old Jan 9, 2003 | 06:35 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: jdm ITR in a hatch (4g4me)
My motor canme with the top half of a Generic Jasma header.
Old Jan 9, 2003 | 06:46 AM
YumVTEC's Avatar
umm... if his motor is 98+ spec then even if the header does reach his stock cat, it won't bolt up because the header has a 2.5" collector. get a JDM ITR (98+ spec) cat, or get a custom one from SMSP. An ITR exhaust can fit on your EG, but may need to be modified for length and/or hanger locations.
Good luck.
Old Jan 9, 2003 | 06:50 AM
eg6ajk's Avatar
if the motor is 96-7 specs then you get 4-2-1 R header with 2.5" outlet. 98-01 got the 4-1 headers with 2.5" outlet. JDM R cat is too short to mate to the stock exhaust on your hatch. R exhaust is too long to fit without modifying. R muffler is extremly hard to slap into a hatch due to small space and will stick out way to much.
but which ever header you get you'll require a USDM lenght cat with a 2.5" collector. so I suggest a hybridgarage.com or others sold for this purpose.
Old Jan 9, 2003 | 01:49 PM
all stock's Avatar
Default Re: jdm ITR in a hatch (eg6ajk)
type r cat is too short. and universal's won't fit. if u need one in a jiffy, u could always get a custom test pipe until u get a cat. then use the test pipe only for the track.
Old Jan 9, 2003 | 02:04 PM
charjacq's Avatar
New User
Not all JDM ITRs come with headers. I believe 98 or 99 on have them. I have a 97 and it didn't come with headers.
Old Jan 9, 2003 | 03:15 PM
TRENDSETTLER's Avatar
Default Re: jdm ITR in a hatch (charjacq)
i dont have an ITR motor, but as far as jdm motors coming with the header i think it just depends...my motor came with a jasma header like the person above stated also...but yeah there is no way that you will be able to bolt up your stock cat to the jdm header as far as i know
Old Jan 9, 2003 | 04:45 PM
all stock's Avatar
Default Re: jdm ITR in a hatch (TRENDSETTLER)
the 98+ jdm itr comes with 4-1 headers. it's a stock factory part. the 96-97 come with an exhaust manifold of the 4-2-1's i think.
gold94accord
Feb 10, 2006 09:42 PM
JDM_Ej
Apr 16, 2005 11:09 AM
genetsang
Jul 12, 2004 07:23 AM
luckypon7
Mar 16, 2004 02:39 PM
cliff666
Feb 21, 2004 09:39 PM
