Greddy Turbo Kit Install Help
Old Jan 8, 2003 | 07:49 PM
incognitoracerr's Avatar
Default Greddy Turbo Kit Install Help
I am installing my greddy turbo kit with greddy intercooler on my D16Z6. I am running it with the engine stock...no changes whatsoever. What precautions can I take to run my turbo without blowing up my engine? How much boost should I go? Say if I can only go about 8psi's does that mean that I can't do redline? Help meeeee!!!!!
Old Jan 8, 2003 | 07:52 PM
rjardy's Avatar
Default Re: Greddy Turbo Kit Install Help (incognitoracerr)
retard your timing, use a BTM or something of the sort. * psi will be fine
Rob
Old Jan 8, 2003 | 08:02 PM
CzanSOHC's Avatar
Default Re: Greddy Turbo Kit Install Help (rjardy)
are you going to use the blue box?
Old Jan 8, 2003 | 08:24 PM
Daniel's Avatar
Precautions? Depends on how much you want to boost. How much you want to boost depends on your wallet.
If you stick to the out-o'-the-box 5.5 psi, no other things are necessary; just run the blue box w/ a bigger fuel pump, and you'll be okay. Do that setup for awhile and then see how much farther (further?) you want to go. And there are those who say you can go up to 7-8 psi on the GReddy FCU with stock injectors/rods/pistons/headgasket/etc. I personally wouldn't want to go over 7 on the blue box, but a lot of people have pushed it pretty far w/o trouble. The longevity of the motor I don't know about, though ... at 8 psi on the blue box, I mean.
And you can still redline at 8 psi or 10 psi or 2 psi. . . . Your motor may not like certain amounts of boost, though, but it doesn't mean you can't redline.
[Modified by Daniel, 5:27 AM 1/9/2003]
Old Jan 8, 2003 | 08:27 PM
CzanSOHC's Avatar
Default Re: Greddy Turbo Kit Install Help (Daniel)
Get some colder plugs as well. and some gauges.
Old Jan 8, 2003 | 08:39 PM
Daniel's Avatar
Default Re: Greddy Turbo Kit Install Help (CzanSOHC)
Forgot about the plugs and gauges.
Old Jan 8, 2003 | 09:35 PM
yeah i will be using the blue box
Old Jan 8, 2003 | 09:37 PM
Thanks for the info Daniel
Old Jan 9, 2003 | 01:59 AM
civicshowracing65's Avatar
Right now I have the greddy turbo kit in my 1997 Civic EX. I've heard that running the out of the box greddy turbo should be fine as long as you keep up with your oil changes, etc... So far I have run my greddy turbo kit for 3000 miles and it is doing just fine. Go here for help or more info....
http://pollito.no-ip.com/turbod16/
or
http://pub19.ezboard.com/fturbod16forumturbod16
Good luck and have fun with your turbo....
YAGGA_YA
Jan 15, 2009 02:44 PM
ex94vtec
Aug 27, 2006 04:01 PM
ktran1
Apr 20, 2004 10:01 PM
SOHC_TURBO_CIVIC
Aug 21, 2003 09:24 PM
horror
Oct 15, 2002 04:54 PM
