lsvtec prices..
i thought ls/vtec was the "cheap' GSR? someone fill me in on why it is so expensive...why not just go with a gsr motor and save the hassle?
or do you mean fully built as in rods/pistons/so on...... if so i can understand why so pricey, and if that the case, how much for a base ls/vtec?
please inform me!
Ian
please inform me!
Ian
Well some people's ideas of well built may differ from yours. I had a B16A3 bought a LS block with type r water pump and oil pump, stock rods and crank with B16 pistons it cost me $1,290.00 then you need need an oil line kit that's about $100.00. But if you need it all trans, head, block.... it can add up quick.
a good running LSVTEC will cost you $4k and up!
reliability issues such as throwing a rod, bent valves, and oil leaks among other stuff will be seen on an LSVTEC that costs $2k
I never thought LSVTEC was a "cheap GSR"; IMO you cant compare an LSVTEC to a GSR, although some people might oh well
hows your car running now? any times?
please inform me!
Ian
please inform me!
Ian
well for reference. we do High compression bottom ends for about $1200. that includes new bearings, ITR pistons, rings, RS MAchine honed/hot tank/bore, new VTEC oil pump, assembly, oil pan gasket and oil filter.
so that gives you an idea on how the bottom end should cost. We are actually doing a high compression LS bottom end Group buy with the same stuff listed about this coming week. should be about $999.00 for all the stuff mentioned above. if interested in that.. feel free to IM or email us.
If you dont have a LS core to send us, we can get one for you. prices on the cores are $200-450 depending on year of B18A or B18B.
thanks
Wil
[Modified by exospeedAMcrx, 8:08 AM 1/11/2003]
thanks
Wil
sounds good and let me know about those details.
i want to ask the question somone else asked but didn't get answer, how much would it cost to get a basic ls to vtec if you have a complete ls from your integra already?
Jdmsolutions
10
Feb 25, 2008 08:30 PM
SiR Inspired ED7
Jul 29, 2006 08:31 AM
SoOHiGH
May 29, 2005 10:15 PM
not so civic
Aug 12, 2003 08:16 AM
if only I had the funds
