2000 Civic Si CAI in a 97 dx hb? Cut a hole in the fender well?
My friend's 2000 civic si CAI goes through a hole in front of the fender well. I don't have this hole in my 97 dx. Did anyone else cut it out? Encounter any problems? Thanks.
Yes you do have to cut it. I reccomend buying a Type R AEM cold-air intake, if you don't feel like cutting. The previous owner of my car cut it, and now I have a Type R AEM CAI, and the hole looks really stupid....you can tell it was done by hand
Yeah, get yourself a Type R CAI. It goes down into the fender, but from it goes in the area near the bottom of the radiator.
Plus - the piping is bigger than a Si CAI.
Anyways, it's not going to hurt your car to cut a hole above the fender well. I'd just find a nice grommet though, so it doesn't cut against the CAI. (that's if you chose to do this)
You have to cut the hole. Isn't the intake manifold shaped different so that an Si CAI wouldn't fit?
. if it's a stock d16y7, this is what you need:
[Modified by cre18, 8:27 PM 1/8/2003]
The tb might be a little smaller, but believe me...it'll work. I used the Type R CAI on my d16z6 engine for a short period. Hahaha...you just have to tighten the bracket down more....BTW: I didn't feel any power increase at all by doing this...but it DOES fit. The SOHC VTEC engines don't flow enough air for it...
) get a 3.5" hole saw from Home Depot. It will cut through the sheet metal no problem. I've used them for car audio installs and they work great.Mike
PM-Performance
Aug 6, 2002 07:26 AM
