Header Install
Old Jan 7, 2003 | 07:02 PM
ultimatehonda's Avatar
Default Header Install
Would anyone know about how high the car would have to be lifted to install a 1 piece header. This would be done with a jack lifting the car from the front.
TIA
Old Jan 7, 2003 | 07:04 PM
B2FiNiTY's Avatar
Default Re: Header Install (ultimatehonda)
Higher the better.
Malice's Avatar
New User
a 2 ton floor jack will lift it high enough
Old Jan 7, 2003 | 07:06 PM
Default Re: Header Install (B2FiNiTY)
Like i want to know cause My jack is a cheap *** one, like it can probly lift the car like 14inches. Im wondering if I need to lift the car from the side or what?
Old Jan 7, 2003 | 07:13 PM
Padawan's Avatar
Darth ModerVader
Jack the car up as high as you can safely get it with your jack (and jackstands, of course) and try to slide the header under it. If the header fits while upright, you shouldn't have a problem with the install.
upright = __)
I apologize for the crude visual.
Old Jan 7, 2003 | 07:15 PM
Dave-ROR's Avatar
Default Re: Header Install (Padawan)
upright = __)
Eh, doesn't need to fit upright really. once under the car with the OEM manifold removed (at an angle) you can install the new one at an angle as well.. it wont go in upright unless you remove some stuff anyways.
Old Jan 7, 2003 | 07:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: Header Install (FyrStarter)
Always helpful to have a little wiggle-room though.
Old Jan 7, 2003 | 07:31 PM
Thanks for the help guys.
Old Jan 7, 2003 | 07:42 PM
Tweakmeister's Avatar
basically, the higher the better.
you can take off the radiator fans to give you a little more room to pivot.
Old Jan 7, 2003 | 08:25 PM
ChapR
Guest
Posts: n/a
Default Re: Header Install (Tweakmeister)
Too bad you didnt live in CA. I would have done it for you for
Old Jan 8, 2003 | 11:42 AM
Default Re: Header Install (ChapR)
Thanks anyways
RallyRedGT-V6
May 11, 2004 02:13 PM
RacerXintegra2k
Dec 31, 2002 09:39 AM
Ryuji
Oct 22, 2002 08:52 AM
CPR
Jun 24, 2002 06:45 AM
onyx00
Aug 18, 2001 09:59 AM
