Power Door Locks (searched)
Old Jan 7, 2003 | 02:13 PM
jaM3s Bond's Avatar
Default Power Door Locks (searched)
Hey guys, just had a Quick Q about power door lock installs.
A friend of mine works at circuit city and can get me some power door locks for REAL cheap. So I was just wondering how much trouble these are to install? I cant imagine them being really hard to install but ya never know. Installs like this end up usually being really annoying.
Any help would be great, thanks.
Old Jan 7, 2003 | 03:01 PM
Turbo Powa's Avatar
Default Re: Power Door Locks (AKA EneMy X)
I would also like to find out this info!
Old Jan 7, 2003 | 04:57 PM
SIMATIC's Avatar
Default Re: Power Door Locks (Panda EK)
CIVIC DX .....i just ordered power locks on ebay, but i already had the relays set up, by the previous owner, so all i have to do it connect the the two wires..the mounting is easy, but the wiring would stay away from!
Old Jan 7, 2003 | 05:05 PM
Airbag Club's Avatar
the worst part of the install is trying to loom the wires through the door grommet. it is extremely hard to wire it through, and be careful for the metal brackets under the dash, as they are very sharp. another hardship i went through was finding a mounting point for the power door lock motor. you have to find a spot where the door lock will fit behind the door panel. i had to modify my door panel, and shave off this piece of plastic to make my door locks fit. hope this helps.
Old Jan 7, 2003 | 05:59 PM
spoon_ek9's Avatar
what do you mean by real cheap? i believe they are cheap as dirt already. $5 for each door lock motor.
Old Jan 7, 2003 | 06:02 PM
MilanoRex's Avatar
Default Re: Power Door Locks (spoon_ek9)
I got them both on ebay for 11 bucks. I installed them a couple of weeks ago, i just had to cut a small hole and bent the metal rod that came with it a little. Works perfect
[Modified by MilanoRex, 7:03 PM 1/7/2003]
Eibach95Civic
Audio / Security / Video
10
Jul 7, 2008 09:55 PM
jbender
Oct 11, 2005 10:24 AM
MugenHonda
Aug 16, 2003 10:01 AM
anomaly
Aug 21, 2002 09:11 PM
TurBoXBirD16
Apr 30, 2002 03:01 PM
