Does a G3 glove box light up ??
Does the G3 glove box light up when opened (while headlights are on) ?
I noticed that the cig. tray does.. but wasn't sure if my gb was gimped (it looked like there was space for such a contraption)
look inside the outer lip of the dash when you open the glove box, on the right hand side should be a spring loaded switch, if your car diesnt have this then it doesnt have a light, if it does and you have no light then the bulb is most likely blown. Theres one on my jdm G3 integra
yes it does light up when your lights are turned on and you open it. mine has a problem where it opens slightly, so the light turns on and off when i go over bumps and stuff... I think I read a fix about someone putting an eraserhead somewhere so the little switch is longer, i dunno... gotta look into that sometime.
My GS-R has a glovebox light.
My base model Camry did not have one, and I got one from a junkyard to add, but never did find the harness where it plugged in.
Mine has a light... and I agree, G3's need more lighting inside. It's amazing what a set of those little crystal white bulbs will do. Sounds ricey, but you'd be amaed how much better it lights up the car. The difference between my map lights and true daylight is nominal.
My glove box is fucked and it kinda stayes open one one side....Light's always on.....****** hella anoying...I gotta pull that light out....
