Anyone use one of these? pic
Old Jan 3, 2003 | 07:32 AM
turboex's Avatar
Default Anyone use one of these? pic
OK were running the turbo and head (b20/gsr) from the stock oil feed location then i planed to run the stock oil pressure gauge and the the electronic autometer pressure gauge from the oil pump fitting using one of these fittings. but how would you screw anything in there as the alt sits so close to it? Anyone have pics of how they used it?
Old Jan 3, 2003 | 07:36 AM
Smashback's Avatar
Default Re: Anyone use one of these? pic (turboex)
I've got one and ran into the same thing. I think if you use a 1/8 to -3 or -4 90 degree adapter it will fit in between there.
Old Jan 3, 2003 | 07:42 AM
bQQsted hybrid's Avatar
Default Re: Anyone use one of these? pic (Hatchblack)
im using one of those too. just use and 90 and it'll fit. it'll be tight, but it works. i'll try to take a picture of it when i get off of work.
Old Jan 3, 2003 | 07:44 AM
turboex's Avatar
Default Re: Anyone use one of these? pic (bQQsted hybrid)
thanks man apic would be nice. im guessing you got the fitting (90deg) at the hardware store?
Old Jan 3, 2003 | 07:48 AM
i got it from a local (domestic) performance shop. it was an aeroquip piece.
Old Jan 3, 2003 | 07:49 AM
Smashback's Avatar
Not if you're using a braided line. You'd need to get the AN adapter from someplace that carries Aeroquip or similar.
Old Jan 3, 2003 | 07:51 AM
turboex's Avatar
i plan to use the autometer oil line that comes with like there manual gauges. i have ran that for over 3years in my nissan and never had a problem
Old Jan 3, 2003 | 07:54 AM
Smashback's Avatar
In that case I think they use standard compression fittings so all it will take is a trip to the hardware store!
APEX CRX
52
Sep 17, 2006 10:53 PM
sasinorm01
May 9, 2006 06:42 PM
crxhfpower123
Apr 3, 2003 03:58 AM
ShortbusEK
Jan 14, 2003 12:29 PM
29psiHybrid
Feb 8, 2002 10:45 AM
