OK were running the turbo and head (b20/gsr) from the stock oil feed location then i planed to run the stock oil pressure gauge and the the electronic autometer pressure gauge from the oil pump fitting using one of these fittings. but how would you screw anything in there as the alt sits so close to it? Anyone have pics of how they used it?
I've got one and ran into the same thing. I think if you use a 1/8 to -3 or -4 90 degree adapter it will fit in between there.
im using one of those too. just use and 90 and it'll fit. it'll be tight, but it works. i'll try to take a picture of it when i get off of work.
thanks man apic would be nice. im guessing you got the fitting (90deg) at the hardware store?
i got it from a local (domestic) performance shop. it was an aeroquip piece.
Not if you're using a braided line. You'd need to get the AN adapter from someplace that carries Aeroquip or similar.
i plan to use the autometer oil line that comes with like there manual gauges. i have ran that for over 3years in my nissan and never had a problem
In that case I think they use standard compression fittings so all it will take is a trip to the hardware store!
