Z10 oil pump fitting
Old Feb 8, 2002 | 08:29 AM
29psiHybrid's Avatar
Default Z10 oil pump fitting
http://z10eng.com/index2.htm In the products section. Part number Z10-6001. Anyone using one of these? I was thinking about using for my turbo oil feed line.
[Modified by 9psiHybrid, 5:37 PM 2/8/2002]
Old Feb 8, 2002 | 09:49 AM
bQQsted hybrid's Avatar
Default Re: Z10 oil pump fitting (9psiHybrid)
Im using one on my B18C1. You don't want to use it for your turbo feed line becaused the oil isn't filtered there (there was a big discussion here a while back on that). I used the oil pressure sending unit's location as a dedicated source for the feed line. Then I ran a steel braided line off of the Z10 fitting to feed an oil pressure gauge, and for the oil pressure sending unit. You'll need to use a 90 degree fitting off of the Z10 unit in order to clear the alternator on a B18C1. HTH
Old Feb 8, 2002 | 10:45 AM
Default Re: Z10 oil pump fitting (bQQsted hybrid)
Good info Thanks!
MotorMouth
Mar 20, 2006 07:12 PM
b18cya
Feb 19, 2003 10:50 PM
MikeMAN
Jul 2, 2002 09:25 PM
Aeka GSR
Jun 23, 2002 06:15 PM
