EK rear disc HELP
i'm wanting to do a rear disc conversion on my EK and i bought the rear disc and LCA from a DC teg but i'm missing brake lines, can i use my factory EK ones or which ones do i have to buy if i need new ones?
THANKS
THANKS
You should also be able to use the rear brake lines from a 99-00 SI. However you need to get the e-brake cables from a 99-00SI. Don't think that you can use the ones from the teg.
cool thanks for the replys guys
so i just use my factory EK LCA with the disc off the teg and i have also the e-brake cable from the teg which i'm going to try and use and now i'm missing is the teg brake lines??
http://honda.hybrids.jp/forum/showfl...&sb=5&o=7&part=
I found this link in an archived post about the same topic. Hope it helps
dc2teg2006
Feb 1, 2010 03:00 PM
1993EG6
Dec 2, 2001 02:00 PM
