Will this work guys? if so is it ok to run like this?
Old Jan 2, 2003 | 03:27 PM
KevronsEG's Avatar
Default Will this work guys? if so is it ok to run like this?
see hoe the externalk wastegate is run. off teh stock wastegate opening. will it work like this and if so is it a good idea Thanks
Old Jan 2, 2003 | 03:32 PM
MayhemSi's Avatar
Default Re: Will this work guys? if so is it ok to run like this? (CIV616)
I ran my car like that for over a year with no problems. I'm not sure how it affects performance, though.
Old Jan 2, 2003 | 03:35 PM
KevronsEG's Avatar
Default Re: Will this work guys? if so is it ok to run like this? (MayhemSi)
so you just have teh exhaust flange an d run teh downpipe and instead of having flange on manifold youjust run it up to teh wastgate?
Old Jan 2, 2003 | 03:37 PM
MayhemSi's Avatar
Its not really "on the downpipe". It is on the wastegate port of that turbo. Some turbos have it and some don't. I had a tubular manifold with no wastegate flange on it so it was my only choice.
Old Jan 2, 2003 | 03:40 PM
KevronsEG's Avatar
i just never thought of that before. so i just need to get a block off flange and cut a hole in it to weld the pipe to? any length fo rthe pipe or not really?
hondateg08
Dec 31, 2008 04:52 PM
B18aHatch
Dec 15, 2005 06:55 AM
hcivic99
Jan 23, 2005 04:31 PM
patdemps
May 10, 2004 08:48 PM
Slater
Dec 31, 2002 07:43 PM
