turbo manifold paint
Old Jan 2, 2003 | 09:14 AM
98civicEX's Avatar
Default turbo manifold paint
is there any paint out there that someone has used w/ success in painting the turbo manifold? i know they make 1400 degree paint. but will that withstand the heat of the manifold?
Old Jan 2, 2003 | 10:00 AM
turbosol's Avatar
Default Re: turbo manifold paint (98civicEX)
VHT Flameproof, good to 1500, been on for about six months and doing great.They sell it at NAPA.
Old Feb 1, 2003 | 11:19 PM
redline201's Avatar
Default Re: turbo manifold paint (turbosol)
got any pics of your painted mani?
Old Feb 1, 2003 | 11:29 PM
Sleepin''s Avatar
Default Re: turbo manifold paint (redline201)
Yup, used 1500deg stuff on this: (sorry, its not a close up or anything)
Old Feb 1, 2003 | 11:31 PM
redline201's Avatar
Default Re: turbo manifold paint (Sleepin')
so this stuff really works?
does it last?
i can paint my turbo mani , down pipe and intercooler piping with this stuff????
sounds to good to be true
Old Feb 1, 2003 | 11:32 PM
Sleepin''s Avatar
You do have to touch it up once in a while. I find the flat black to work and look the best.
Old Feb 1, 2003 | 11:37 PM
redline201's Avatar
ah i knew it
i cant decide if i shoud jet-coat everything
or wrap it
or paint it with the 1500 degree paint
i spent a grip of $ on my setup
i dont care about bling bling
but max rev manifolds look nasty (all brown and rusty looking )
i want my setup to look clean
Old Feb 2, 2003 | 12:07 AM
Tofurky's Avatar
i used the VHT... i'm sure i'll have to touch up every now and then... but it looks much better than those shiny manifolds
Old Feb 2, 2003 | 01:39 AM
SoulSurfer's Avatar
Default Re: turbo manifold paint (Ruckus138)
Hatchblack showed me this site...
http://www.performancecoatings.com/benefitdata.htm
Look at some of the pictures. If you don't like the bling look they also have a few other finishes that withstand 2,000 degrees F.
Old Feb 2, 2003 | 06:46 AM
evoeone's Avatar
Default Re: turbo manifold paint (LSDelSol)
i went to home depot and bought high temp paint for like bbq grills, holds till about 1500, hasnt flaked, looks great. since my manifold is cats, i just wire brushed and sanded the excess rust dust, dryed it, then heated it a bit under a lamp, sprayed it a few times, and let it dry. worked great and the paint is intact. try that before a hundred $+ ceramic or that other crap
Mensuro
Jun 3, 2011 07:19 PM
IntegraMastaz
Dec 12, 2005 04:19 PM
StolenTeg
Aug 13, 2004 10:34 PM
BobGnarly
May 31, 2004 10:10 AM
its WANG yoO
Nov 20, 2002 03:40 PM
